Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 11-16-2008, 12:30 AM   #1
lorakew
2005 mustang EVAP problem
Hi all,
The check engine light came on, and i used my code reader and pulled code P0456.
EVAP small leak detected. I looked in the haynes manual and it suggests about 6 components of the EVAP system.
Lately i've noticed that when i pump gas, the gas pump clicks as if the tank is full, but the tank is actually only about half full.
Any ideas about where to begin?
2005 Mustang V6
-L.L.
lorakew is offline   Reply With Quote
Old 11-16-2008, 01:35 AM   #2
Scrapper
AF Premium User
Re: 2005 mustang EVAP problem
no dent in gas tank right? even if it kicks off you cant put more in it? i'm thinking float in tank. have you you checked all vaccums going to canester you may want to check other vacumm line you see..
Scrapper is offline   Reply With Quote
Old 11-20-2008, 04:52 PM   #3
lorakew
No, there are no dents in the gas tank.
When i'm pumping gas, and the pumping kicks off, i can put more gas in it, but it keeps clicking off. I just do it 10 times until the tank is more towards full.
are these vacuum lines going to the canister accessible?
Old 11-20-2008, 04:54 PM   #4
lorakew
I am also wondering if it is common for this code to replace the canister purge valve
