Go Back   Automotive Forums .com Car Chat > Dodge > Stratus
Old 09-07-2008, 06:21 PM   #1
DRSN777
dying out
stratus dying out in middle of road....
GA_googleFillSlot("Forums_ROS_300x250_noad");hello peeps;
i have a problem with my 99 dodge stratus, when i start the car it's fine, but when we take off it dies out 5 mins later, we start it up again and 5 mins later it dies out, this happens on and on through out the travel time, i hooked up my OBD II scanner and it read EGR VALVE MALFUNCTION, i replaced the egr vavle the one that i recieved from the dealer the part no from the dealer is 04287827AC, but my original part no is 04287827AA, they both look exactly the same, but when i put the new one on its still the same problem, any help would be greatly appreciated........ frustrated.......
thanks dave
DRSN777 is offline   Reply With Quote
Old 09-08-2008, 07:27 AM   #2
DRSN777
Re: dying out
forgot to mention the OBD CODE
P0400
any help would do.
do i need to replace the fuel filter/pump/or sending unit.
i replaced the fuel filter earlier this year about 5 months ago.
help---------------------
the car just dies out but starts up fine..........
Old 09-08-2008, 03:45 PM   #3
zique
Re: dying out
Something worth looking at is your relays. I'm not sure how that work on these cars (having never owned one) but a lot will have a relay that will send power to the fuel pump for the first few minutes until the engine builds enough vacuum to keep the fuel in supply. Maybe your relay is getting the pump to send that initial prime, but you're missing vacuum somewhere after the relay shuts off.
zique is offline   Reply With Quote
Old 09-13-2008, 05:25 AM   #4
DRSN777
Re: dying out
help anyone....................
Old 09-13-2008, 03:06 PM   #5
dsramprat
dsramprat's Avatar
Send a message via MSN to dsramprat Send a message via Yahoo to dsramprat
Re: dying out
Did you replace just the EGR valve? I don't remember the exact name for it, but there is also a EGR control valve on these cars. It is right by the EGR valve, made of black plastic, has one electrical connector on it and vaccum lines. There is a solenoid in there that likes to go bad. If that craps out, yoiu have no control over when the EGR valve opens and closes.
Try it. It has worked for me in the past on a 1994 Dodge pickup, but the stratus has the same setup.
Bending wrenches and turning air into the Sound Of Freedom!!!
dsramprat is offline   Reply With Quote
Old 09-13-2008, 04:07 PM   #6
DRSN777
Re: dying out
yes i replaced the egr valve and vacuum solenoid, it comes togehter when you pruchase it from the dealer, but when i replaced it,,, it's still the same, it just dies out every five minutes...........
thanks
dave.
Old 09-16-2008, 05:31 AM   #7
DRSN777
Re: dying out
o ok i think i got the picture, the last resort might be a flow restriction in the intake manifold, i think, well so how do i clean the egr ports or the inside of the intake manifold, pls give me some tips, or a site that could help me out,
determined to git hur dun,and out of the way.
dodge,dodge dodge.........................
was a wrong move to purchase this car used.......
