Old 08-15-2008, 11:07 PM   #1
RollDBlunt
RollDBlunt's Avatar
Added coolant = Screwed everything
So I drained the coolant and then added coolant went to start it, there was a crack sound and now it runs very noisily. diagnosed please
'92
Eagle Talon TSi AWD
RollDBlunt is offline   Reply With Quote
Old 08-16-2008, 11:31 AM   #2
Dodge1063
Re: Added coolant = Screwed everything
When i replaced the coolant in my car (A 1995 Cutlass Ciera) *It does have the 3.1L in it.* I drained the coolant out plus ran the heater so that coolant would leave it. When i added more coolant i filled it up to top and let it stand for a minute. While the car was off and the fluid was topped off, I started the car while the heater was running. Coolant will then flow through the heater core and then i just add more coolant into the reservoir. I have read before you have to keep running the car with heater on otherwise when you drained the coolant the car is not getting the fluid to be cooled. I also read it could crack the block because of the difference between areas getting radiator fluid and not, but not sure on that.
How did you replace your coolant? Did you turn on the heater?
Dodge1063 is offline   Reply With Quote
Old 08-18-2008, 12:17 AM   #3
Forscythe87
Are you sure you added the coolant where you were supposed to?
Did you make sure you didn't drop any caps and get anything caught in the belt? How much coolant did you drain and how much did you add?
Sounds like you may have not put enough coolant in and you overheated something = broken.
Where is the noise coming from, and what kind of noise is it.
1998 Chevy Lumina LS 3.1L 126K Miles
Forscythe87 is offline   Reply With Quote
Old 08-18-2008, 09:47 PM   #4
sad-lumina-owner
sad-lumina-owner's Avatar
OMG - this sounds ominously bad...
I really sympathize with you. Changing the coolant should be a simple, safe and harmless operation, or else some engineer should be fired.
Maybe its (just) the waterpump? That could be relatively cheap compared to a new engine...
Good luck
sad-lumina-owner is offline   Reply With Quote
Old 08-19-2008, 12:16 AM   #5
nickapalooza
Good luck
That's a very dim view of the said "ominous" problem. Way to hate on GM.
nickapalooza is offline   Reply With Quote
Old 08-19-2008, 03:03 AM   #6
sad-lumina-owner
I like GM, as international corporations ruled by unpatriotic elite superrich go.
Next I suppose some twit will call me out for criticizing Haliburton corp. and the mayor of New York.
So bring it on. Only at least bring it. A brain I mean.
I don't want to have a battle of wits with an unarmed man.
So do your homework first, say here:
http://www.crooksandliars.com/
http://www.truthout.org/
http://infowars.com/listen.html
http://breakfornews.com/forum/viewforum.php?f=1
For an extra course in not being stupid, try these too:
http://poisonevercure.150m.com/popul...ol.htm?115,132
http://drjudywood.com/articles/DEW/StarWarsBeam5.html
http://www.larouchepub.com/other/200...o_oks_ddt.html
http://www.memritv.org/
http://www.rotten.com/library/conspi...idge-incident/
http://brownwatch.squarespace.com/po...lity-archives/
http://www.prothink.org/
http://www.awitness.org/column/sin_military.html
http://www.friction.tv/ftv_debates.php?debates_type=1
http://vaticanassassins.org/
http://www.counterpunch.org/whitney07012008.html
Old 08-19-2008, 03:18 AM   #7
nickapalooza
DON'T ATTACK EACH OTHER
Attack the message, not the messenger. Criticize ideas, not the person. Don't attack others. Personal attacks and flaming on others will not be tolerated. Challenge others' points of view and opinions, but do so respectfully and thoughtfully ... without insult and personal attack. No violent, discriminatory language or personal attacks are allowed. Personal attacks are defined as personal, racial, ethnic and or gender based insults, slurs or derisive comments. We reserve the right to edit and remove any inappropriate posts.
Forum Guildlines.
