Low Coolant Light only when cool startup to op temp.
02 Impala 3400 71K radiator flushed and dexcool replaced with "Complete" a dexcool compatable product last fall. I have NO Coolant Loss whatsoever, No overheating. Read through thread searches and cleaned LC sensor. the result was it was a bit dirty, cleaned, put back in solved problem of light staying on all the time. Now the light comes on at cool start then goes off as engine reaches Operating temp...system was properly bled at bypass and thermostat. Again no coolant loss nor performance issue. My thoughts are that it is either a bad pressure cap or the thermostat is malfuntioning of which the latter does not make sense to me due to proper operating temps. Heater works as normal airconditioning also working normal. Again NO Measured coolant loss over two week period 1000 miles. Radiator is full when cap removed cold....normal warm up when cap left off and light goes out....at op temp....
littledave~ Last edited by 57chevyragtop; 05-31-2008 at 07:21 AM. Reason: To clarify title |
Re: Low Coolant Light only when cool startup to op temp.
What brand coolant did you use? I noticed over the years some members have complained about the low coolant indicator not working properly after switching coolants like from Dex-cool. Including after replacing the level sensor. I don't recall any resolution to the issue either although a lot of us do not get the problem. Must be some kind of variable. Some are disconnecting the sensor to get rid of the light but checking coolant levels in the radiator and reservoir monthly.
Just out of curiosity try running a conductivity test. With a DMM on dc volts at lowest scale dip the positive lead into the radiator opening in the coolant only and black lead to battery ground. See what you get for a reading.
Re: Low Coolant only when cooldown startup
Thanks for the response BNaylor, Well the garage that I had the flush done said it was called complete (Komplete)? never heard of it but I figured he new what he was doing as he said it was dex cool compatible...and Biodegradable..all was OK thru winter till I took a 350 mile trip and light came on, on the way back about 200 miles out. Just watched the temp the rest of the way with no rise in temp above 190-5. I don't get any reading on DMM Batt ground to coolant, however do get 13.6 V one side of sensor...I have cleaned the sensor but thinking I need to drain and flush system again as it seams a little cruddy to me. Probably left over from the dex-cool sludge before the flush. this being My first experience with that coolant I didn't reallize it cood turn so quickly...on month it was fine then a month or so later it was sludgy (is that a word?). By the way that is what he told me about the unplugging the sensor but I don't see that as a solution to live with. At this point I am a bit stumped hence search and post here.
littledave~ |
Decided to clean the cooling system and sensor so I drained the anti-freeze, flushed the block and the radiator+recovery tank. Refilled with water only for a couple of days may put some flush in. But results the same so far...
Yeah sometimes it takes awhile to get all the old Dex-cool and any possible remaining crud/sludge out so a repeated flush is not unusual. About all I can think of is the level sensor?
BNaylor: WOW...I just stopped at the dealer to buy a new cap to start with. Parts guy asks me why? I tell him the story as I did here and he says to me " I guarrantee you it's the sensor gone bad...says he sells 2 a week. Well they're 65 +tax title and first born....I found an ACdelco online for 37+ship so I'll probably go that route....I think you are right and kudos to ya.
littledave~ |
Update: 6/10/08, put in a new sensor yesterday and so far it's working. I have yet still to replace the antifreeze but I will be using Dex-cool. I understand that I could go with the ethylene glycol Green but want to use original setup when ever possible. It's strange to me that 5-6 quarts are recomended when it only comes in gallon jugs, brilliant. why not a 6-pack!?
Oops, I was thinking out loud, sorry bout' that. |
New update: Low coolant level light back on and staying on now...Puzzled? Yeah, I are! I just threw 60 bucks away on the sensor, Argh!
57chevyragtop:
Your intake manifold gaskets are probably leaking. Everything you've mentioned I've already been through with my '02 3.4l Impala. And I started noticing a problem with my car around 65k miles (close to where your mileage is right now). I also didn't think I was losing coolant, and my car wasn't overheating either (and it was running perfectly fine). But over a longer period of time (months), you'll probably see that the coolant level drops and you'll have to keep adding fluid. When you pulled out the radiator sensor (which I also did), was it muddy with brown-colored slime around the center post (that you wiped off)? If so, that's oil leaching into your radiator. Check the backside of your radiator cap. Same thing? It's oil in your coolant. You probably DO have enough fluid in your system, but once that center post gets gunked up, the LOW COOLANT LEVEL message appears and it doesn't go away until you pull out the sensor and clean it off. Check the side of your engine block behind the power steering pump. Look along the diagonal black "V" seal running from the valve cover down to the center of the block. Do you see any damp-looking spotting along this seal? Look down below this seal into the trough formed by the shape of the block. Is it wet and muddy-looking down in there? If so, coolant is slowly leaking out the "V" seal and dripping down into the collected road sand to form the muddy mix. I monitored my car from 65k to 100k, checking the fluid level often and watching for leaks (adding a bright green dye to the coolant at one point only to see it bubble out the side of the block), until I finally replaced the gaskets about 1500 miles ago. So far, no leaks (block and trough are nice and clean and dry), no LOW COOLANT messages, and no brown sludge on the underside of my radiator cap. Really sounds like you've got the same problem I had. Three years ago, a guy at an auto parts store told me, "they (GM 3.4L engines) all leak". I didn't believe him then - but I do now. Co-worker is driving a 2003 Impala 3.4L. Guess what? It has the same dampness spotting on the side of the block that mine had. It'll only be a matter of time before the LOW COOLANT message starts appearing on that car, too. |
Thanks Colt Hero, I will check that today, and yes I do have the brown sludge you speak of on cap and the sensor. I was hoping against hope for that situation I will repost finding.
Results: Thermostat did the trick, system was well cleaned as well and put in 6 qts of Dex-Cool and filled with distilled water. No Light now. I will admit though it is a difficult part to replace in this engine design. Crossover exhaust pipe cover needs to come off as well as the throttlebody return pipe/heater inlet hose. Getting either back on is just as difficult as removal....So there is my story and I'll stick with it......dave....Thanks all!
OK, but I'll also have you know that I flushed my system too - completely re-filling with the standard green stuff instead of Dex-Cool (I use the "mixes-with-anything" SuperTech stuff sold at Wal-Mart - I think it's actually yellow in color). That was three years ago now. The light came back on anyway.
My guess is the T-stat change had no effect - you probably could've just poured more coolant in to make the light go out. Good luck! I hope that's the end of it for you, but don't be surprised if it isn't... |
Thanks Colt Hero, genuinly understand your point. I have reservation as to the presant fix being the end of it. If I have to tackle the more difficult task of LIM gasket replacement, I'll just have to do so. As far as GM and Chevy product this is definately my last. My 92 Lumina was a much better car and a great deal less costly to maintain. This one has cost more in 3 years than the 92 did in 12 years...Time to sell me thinks!
I went thru the same ordeal with my 3.8L... Wasn't properly fixed until I had the UIM and LIM gaskets replaced...
Go Mark Martin! |
Funny, but I'm looking at my records right now ... I got my first "LOW COOLANT LEVEL" message at exactly 67,650 miles (on 10/29/05). My annotation says, "message appears for ~ 5 miles at startup only" - which is exactly what the title of your thread says. Surprising to me, but I had actually flushed out the Dexcool at 60,800 miles on 5/30/05 - BEFORE the first LCL message. I remember now reading about theories that the Dexcool was to blame (which I didn't believe), but I got it out of there anyway because it was easy and needed to be done.
Subsequent to this, (looking at my records further) I had to add coolant 8 months later on 6/11/06 at 78,405 miles (~1 Qt!), then again on 11/27/06 at 85,450 miles (~.75 Qt), then again on 2/4/07 at 89,596 (2/3 Qt), 3/11/07 @90,409, 4/8/07 @91,226, 5/10/07 @92,295, 5/29/07 @92,976, then I changed the sensor on 7/5/07 at 93,859 (needlessly, as it turned out), still the light came back ON on 9/13/07 @ 97,495 miles. Boy, it's really shocking me right now that I added coolant that many times - especially the increased frequency toward the end.... THEN, I finally got the wake-up call: VERY LOUD ENGINE CLICKING NOISE on 3/24/08 that did NOT go away even after warm up. This scared me enough to pour in 8oz of SeaFoam 5 days later at 104,537 miles. Then I finally changed the gaskets on 5/6/08 (the car quieted down enough to allow me to wait for the optimal time, but it wasn't due to the SeaFoam). I used the Fel-Pro gasket set (~$80), replacing the upper, lower intake gaskets, plus all the other stuff: T-Stat, Oil pump drive o-ringl, plugs, wires, valve cover gaskets, coolant bypass o-ring, injector o-rings, o-rings on fuel rails, t-stat coolant pipe o-ring, but I re-used the original bolts (applying blue threadlocker). Also replaced all 12 valve lifters because the clicking was probably an indication that at least one of them was damaged. Only paid $8/lifter at Autozone (Melling). You can do this repair yourself if you're reasonably handy. It just takes time. No special tools - unless a low-torque torque wrench, or a Torx ratchet bit are "special" to you. I also ended up buying a 1/4" slim-line ratchet and socket to remove the lower bolt on the T-Stat housing. Even after removing the exhaust cover, it's still really tight getting that lower bolt out! Also bought a 1/4 extension and a deep socket for the bolt at the rear left of the UIM, plus a universal socket to torque the diagonal bolts on the LIM. |
