Go Back   Automotive Forums .com Car Chat > Hyundai > Accent | Verna
Old 06-08-2008, 06:55 PM   #1
RinNC
Replacing the door handle
I have an 2000 accent, with a broken door handle. I am trying to replace it,but having trouble taking the door panel off. I can not get the window handle (used to roll the window down) off. Is there a trick ? What other surprizes am I going to run into?
RinNC is offline   Reply With Quote
Old 06-24-2008, 01:24 PM   #2
nickoolsayz
Re: Replacing the door handle
there is a little clip on the inside of the window roller. use a thin flat screw driver and pop it off. remember to put it back on or the handle will vibrate and fall off, its a bit harder to get on than off. should be good to go. (i didnt remember having to take the panel of to put a door handle on)
u replacing handle - the piece you pull on to close door.
" - the level to open door from inside.
not sure what ur doin but hope i could help.
nickoolsayz is offline   Reply With Quote
