Go Back   Automotive Forums .com Car Chat > Oldsmobile > Bravada
Old 08-12-2015, 06:49 AM   #1
beir
old dog learnin new trick
beir's Avatar
98 bravada running a little hot at highway speeds
My 98 runs up to 235 when at highway speeds.. especially when outside temperature is over 80 degrees outside...changed water pump..still have problem..is this normal maybe? Had 95 s10 and it never went over 195..any help would be appreciated..thanx
beir is offline   Reply With Quote
Old 08-12-2015, 05:17 PM   #2
beir
beir's Avatar
Re: 98 bravada running a little hot at highway speeds
Something to add...there is no water in oil..and radiator is full..once it gets hot it never really cools down..or takes quite some time to cool down
Old 08-12-2015, 06:33 PM   #3
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
The radiator may need cleaning/replacing.
Does the fan roar when it gets hot like that?
Check the outer radiator for dirt, leaves etc.
Chris Stewart is offline   Reply With Quote
Old 08-13-2015, 12:11 PM   #4
beir
beir's Avatar
Don't hear fan..took hose and washed the radiator from engine side and front it helped a little..no smoke coming from exhaust..might need a new radiator..thanx Chris..
Old 08-13-2015, 04:56 PM   #5
Chris Stewart
AF - Advisor
The fan should be turning extra hard while the engine is hot like that.
Old 08-13-2015, 04:57 PM   #6
Chris Stewart
AF - Advisor
I generally see 195-200F on mine.
Old 08-13-2015, 11:36 PM   #7
ericn1300
AF Premium User
ericn1300's Avatar
You are about 500 feet above sea level so yours should run about 215 fully hot and pressurized. Usually over temps at speed are an airflow problem while over temps at idle are coolant flow problems so I don't think you need a new radiator. Go back and take another look both sides of the radiator for air blockages and debris. The Bravada's are notorious for picking up lots of leaves. Also the first thing I do whenever I have an over temp or even smell some anti freeze is to get a new radiator cap. Cheap fix if it works and your going to want a new one if you have to replace the radiator anyway
ericn1300 is offline   Reply With Quote
The Following User Says Thank You to ericn1300 For This Useful Post:
Chris Stewart (08-14-2015)
Old 08-14-2015, 06:08 AM   #8
beir
beir's Avatar
Thanx for the replies guys..well last night on way home I had ac off outside temperature was bout 90 and it got up to 225..got off freeway and engine temperature stayed constant.when I turned into the wind it cooled down back to bout 200..I think I'm getting good air flow through radiator..I'm gonna try new clutch fan and see what happens since I don't hear it working accept when it first starts up. One thing bout radiator cap..it has a "lever stant" cap...maybe I'll put regular cap on..even though it looks in good shape.. thanx again for the replies
Old 08-14-2015, 04:40 PM   #9
Chris Stewart
AF - Advisor
The radiator hoses should be tight with pressure at normal running temperatures.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 08-14-2015, 09:14 PM   #10
beir
beir's Avatar
No leaks.. got clutch gonna put it in tomorrow
Old 08-18-2015, 03:58 AM   #11
beir
beir's Avatar
Well I put in new fan clutch..drove around town at slower speeds..did some extended idling when engine warmed up..never went above 210..went to work..no problems...came home from work it went to 220..got off freeway had some stop and go it went to 240..don't know what the problem is.still can't hear fan with new clutch..but at idle its pulling air..(did cigarette test) heard some one talk about air in system..but I always thought it works itself out..don't know how to get it out if that's the problem..
Old 08-19-2015, 12:24 AM   #12
Chris Stewart
AF - Advisor
While cold with the radiator cap off, park it at a fairly steep incline, passenger side/front high...I park in the ditch and let the engine warm up. If it just pukes with no air being burped out, it's full and you might consider removing the radiator and cleaning it with the garden hose or let a radiator shop flush it with their combination of air and water.
Old 08-20-2015, 12:20 PM   #13
beir
beir's Avatar
Cool I will give it a try...thanx Chris
Old 09-13-2015, 02:02 PM   #14
beir
beir's Avatar
Well got problem fixed..it was the radiator...the one good thing about this is that everything but the heater core has been replaced..hoses..thermostat..everything. took it down the highway at 75 mph with ac on for 20 miles and temp nver went over 190....(I put in 180 thermostat)...thanx for all the help I hope if someone else has this problem this series of posts helps them out
The Following User Says Thank You to beir For This Useful Post:
Chris Stewart (09-15-2015)
Old 09-15-2015, 12:30 AM   #15
Chris Stewart
AF - Advisor
Thanks for the update beir!
