Old 04-10-2005, 01:34 AM   #1
bstrom1953
Replacing the exhaust manifold on a 3.1?
How do you find room to replace the exhuast manifold on a 95 3.1? Is it possible to remove the upper motor mount arms and move the top of the engine towards the front of the car?
bstrom1953 is offline   Reply With Quote
Old 04-10-2005, 10:35 AM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: Replacing the exhaust manifold on a 3.1?
Yup. Just take those out. Take them out, don't just loosen one end, or they might get in the way or punch holes in something. After that the motor is just teetering on center mounts, and can be rolled easily. I do it by rocking the car back and forth in park, that gets the motor pitching, then I stomp the E-brake when it's as far forward as it will go, and block the wheels. For something like what you are doing, you might want to do something more secure. You can use a ratcheting tie down to pull the motor forward to the core support, then block it against the firewall with a piece of wood or something like that. The you'll have plenty of working space back there.
Don't forget to put them back in before you start/drive it, the motor will slam your radiator. (You laugh, but I've seen it done.)
Good luck!
...empty gun rack.
Old 06-06-2008, 12:12 PM   #3
dafeeder
Do you have to take anything else loose such as the exhaust or drain the radiator?
dafeeder is offline   Reply With Quote
