Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 02-20-2008, 09:32 PM
oscar47 oscar47 is offline
95 riv no sig to injectors
Trying to get a 95 sc Riviera running. Checked the injectors with a noid light, no signal. What's the most likely culprit? Also, where in the world did The General hide the bloody fuse boxes on this thing??? Any help greatly appreciated.
Old 02-21-2008, 10:26 PM
dwn757 dwn757 is offline
Re: 95 riv no sig to injectors
Wow..simular problem now with my 95 riviera.
I can tell you to look under th back seat, some fuses there and on the left side of the dash as you open the driver door...a small fuse panel there.
Old 03-03-2008, 10:34 PM
Apparently found the problem. Seems to be a broken wire 'tween the rear and front fuse boxes. Patched in a jumper and all is well.
Old 03-06-2008, 03:34 PM
Exclamation Re: 95 riv no sig to injectors
please tell me...exactly where and what color was this wire. I am have exact same problem.
Old 03-06-2008, 04:01 PM
Mickey#1 Mickey#1 is offline
May not be the same problem. So until he answers:
Start by checking for 12 volts (key on) between the pink injector wires & ground. If you don't have 12 volts then check all fuses. Does the Riviera have fuses under the dash on passenger side?
If pink wire has 12 volts then try unplugging the throttle position sensor. Let us know what you find.
