Old 02-24-2008, 09:22 AM   #1
viperman-1102
Re: Tailligths, dashboard lights off all the time
Hi guys,
Having the same problem.
I have a 1996 Lumina and lost my dashboard lights and the tail lights. Checked fuses under hood drivers side and found where the 'park lps' 25amp fuse and socket were corroded. Cleaned up and replaced with new fuse. However, no change. Looking at the bottom of the fuse box I noted that one leg of the new fuse has no wire coming to it. How is this possible? This leads me to believe that the 'park lps' fuse is not the culprit or that the wire may have corroded and fell off. But cannot see any loose wire. Any ideas ?
Thanks a lot.
viperman-1102 is offline   Reply With Quote
Old 02-24-2008, 12:06 PM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
Welcome to AF.
You post was moved because you posted in an outdated thread.
WE try not to bring up threads older then three months.
Sounds like your wire has corroded off the lead.
You will need to find the loose wire and reattach it to the contact it belings to.
Good Luck
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
