Old 01-06-2008, 07:25 AM   #1
JohnABurns
Blower motor speed varies with speed
I have a 96 with 3.1. Fan speed is ok when I start but as I slow down to stop the speed decreases and then picks up as I accelerate. The headlights and turn signals will effect it also. Any input is appreciated. Thanks
JohnABurns is offline   Reply With Quote
Old 01-06-2008, 10:42 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: Blower motor speed varies with speed
Sounds like your alternator might be failing...get it's output checked, or you could get stranded....
Usually when you notice something like that, there's not enough voltage under load, the accessory pulling the most load will cut back...output is lowest at idle.
Otherwise it could be a bad ground in the blower circuit or something...
...empty gun rack.
Old 01-07-2008, 05:58 PM   #3
KKLumina
... or a bad belt tensioner.
KKLumina is offline   Reply With Quote
Old 01-29-2008, 12:08 PM   #4
nascartony05
nascartony05's Avatar
I have had one with similar symptoms and it turned out to be a vaccuum line at the canister.(front left hand side?)
nascartony05 is offline   Reply With Quote
