Register FAQ Social Groups
Old 02-09-2003, 07:14 PM
trifocal trifocal is offline
Angry Ground points????
Hello, I was wondering if anyone out there knew why when I turn on my headlights it loads up and engine and it starts surging? Could it be ground points? So far.. new alternator, new battery, moved some ground points, added ground points etc. This is driving me insane!!!
Old 02-10-2003, 11:44 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
When you turn on the AC, headlights, or any other high-draw accessory, the engine has to put out more power. Typically there is a control system that increases the throttle opening & engine speed to compensate for the increased demand (at idle). If this system is malfunctioning, you may see symptoms like what you are describing. Check your "idle air control" system (IACV, etc) first.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
