Register FAQ Social Groups
Old 02-04-2003, 08:36 PM
Crxce Crxce is offline
Send a message via AIM to Crxce
zc motors come vtec?????
Do zc motors come vtec and if so anyone no a web site were i can find info and a swap kit for a 88 crx dx Thanks
Old 02-04-2003, 08:37 PM
kris's Avatar
kris kris is offline
Off playing with fire.
No vtec with a ZC motor.
Old 02-04-2003, 08:40 PM
sucks
How much does a zc swap go for
Old 02-04-2003, 08:49 PM
kris's Avatar
Originally posted by Crxce
sucks
Motor trans and ECU about $800 + shipping.
Take away the trans and ECU and they run less.
Old 02-04-2003, 09:04 PM
KNow were i can buy the tranny, motor, and ecu from online?
Old 02-04-2003, 09:17 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
well, you can use the Si ECU, so, that will save u some $$ and the Si tranny or your stock DX tranny, they both work, just get the longblock and what ever u need for the MPFI swap......
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 02-04-2003, 09:27 PM
stock mounts will work???shift linkage?
Old 02-04-2003, 09:29 PM
MyFirst4G's Avatar
Yep, motor mounts will be fine, but its recomended to replace the bushings inside the mounts and if you have any broken mounts to change em before the swap..... and yea, stock shifter linkage will work fine!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 02-04-2003, 09:45 PM
this is great is the zc motor and alright swap? is the b16a much better to go with or does each have its advantages are parts easy to come buy like after market for a zc motor
i know you can find them easy for a b16
This swap will be alot easier and less complicates then the b-series and alot cheaper i might go with this for now if its a good swap i wat to turbo in to future the zc is better to turbo casue of the lower compression ratio? thank for your help
Old 02-04-2003, 09:48 PM
MyFirst4G's Avatar
Yes, the DOHC ZC is a good swap, but i would rebuild my motor because i've heard that a ZC motor usually sits in one place for a while...... and i would rather put in a SOHC d16y8 motor because it has VTEC..... Power wise, it would come down to the driver...... if it were me, i'd go with a b18a and turbo it because its also DOHC, but its 1.8L's and low compression and i can put a YS1 tranny on there which has LSD..... but its also a lot more money because its a B series engine and i'd have to buy new mounts and linkage and a tranny, etc......
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 02-04-2003, 09:53 PM
oh the zc's are sohc that sucks? wich are better to turbo?
Old 02-04-2003, 09:54 PM
MyFirst4G's Avatar
NAA, the ZC comes in BOTH DOHC and SOHC, but the SOHC are rare, and not worth it, IMO, i'd go with the more popular and easier to come by and BETTER DOHC!
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
Old 02-04-2003, 09:57 PM
oh thats cool so most zc motors id buy would be dohc? cool. but do you know wich are better to turbo? b16a or zc series
Old 02-04-2003, 10:01 PM
MyFirst4G's Avatar
yea most ZC's u'd find will be DOHC, and when it comes down to turbo, i'd rather do a b16a, but then it really comes down to finance!! and if your going to turbo either motor, i suggest building it up if you wanna put more than 5 or 6 psi, but if you have the right Fuel Management and a Intercooler, you can run more boost, check out this link http://www.thedropshop.tv/custom and he usually comes on here, he has a ZC motor and its turbo'd and he has stock internals and i think he runs like 11 psi of boost safely cause of a ZDyne ECU or something....
88 DX Hatch SOLD!
96 Saturn SL2:
91 DX Hatch:
Official 4th Gen OG
Hype Race Crew
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
