| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
hello to all first post hope ya all can help me out , well here it goes
when I am at a stop I am getting like a misfire but it does not stall , or as some may say ruff idle. lights in dash will dime a bit when this happens ,and more so when I have the heat on high.now things I have done to this car, put new injector in as other had a leak. blower motor rely went ,and also come to find out that the motor had a dead spot in it to (real impressed with having to get under there again) have changed the fuel filter have put fuel injector cleaner in it have checked for bad ground, dielectric grease on the batter posts have had battery and alternator checked both are working fine . system diagnostics done no falts detected. new coil pacs later summer , but the ruff idle just started so don't think it has to do with that do any of you have any ideas to what I can do next to figure this problem out ? thanks in advance for any help that you ppl may provide |
Re: 1995 sunfire stumped
I have something similar happen, when my radiator fan kicks in.... car will vibrate some, and the lights dim a bit.
If your running hot, and the fan is having to kick on as soon as you quit moving, *shrugs* Just my . |
Engine size would be helpful. Check plugs and wires. If no wires (2.4L), try replacing the plastic "cover" over the engine. Those go bad and cause a rough idle. I've also seen a failing ignition module cause that.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
sorry for not posting engine size , is 2.2
