Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Register FAQ Social Groups
Old 03-18-2021, 10:27 AM
roadbum roadbum is offline
S-10 4 wheel drive tranny problem
I've got a 2002 Chevy s-10 4 wheel drive. Don't drive it a whole lot but I've now noticed the transmission won't shift properly or go up through the gears when I accelerate. It's like it's stuck or something
Old 03-18-2021, 11:16 AM
ctesla's Avatar
ctesla ctesla is offline
Re: S-10 4 wheel drive tranny problem
roadbum,
Welcome to Automotive Forums..
it could be something simple.. start with checking fluid at temp..
a lower fluid amount would cause lack of, or slow/harsh shifts;
or it could be that the TVS cable is stretched, or come loose from the
throttle body intake??
start simple, then work to worst case scenario..
Old 03-19-2021, 01:39 PM
Originally Posted by ctesla View Post
roadbum,
Well the fluid was extremely low at one point almost to the point of not moving. I put fresh fluid in and it will roll down the highway but it just wont go through the gears properly
Old 03-19-2021, 01:52 PM
ctesla's Avatar
how many miles? was it functioning properly last drive; or has this progressively gotten worse? when you pulled stick to add, did it smell like burnt trans fluid? when you say 'roll down the highway', does this mean you can drive and get to hwy speeds, but it just slowly accelerates to those speeds; no physical shift and rpm increase/decrease when you hit a shift point to go from gear to gear?
Old 03-19-2021, 11:15 PM
Blue Bowtie's Avatar
Registered Offender
Specifically, which ranges will function? Also, does manually shifting the ranges change the shift quality?
Old 03-23-2021, 03:44 PM
As I increase speed the tranny just won't shift through the gears. I don't smell anything like burnt tranny fluid. I can't get up to highway speeds (50 to 60 mph etc.)
Old 03-23-2021, 08:15 PM
ctesla's Avatar
as Blue Bowtie suggested, if 'manually' going through the automatic 1/2/3/D gears does not engage the trans manually, it might be a TVs cable; low fluid, or damaged valve body.
Old 03-28-2021, 06:36 PM
j cAT j cAT is offline
zzzzzzzzzzzzzzzzzzzzzzzzzz the GM DEXRON III IS a fluid that creates acid @20K miles, change the fluid and filter . use DEXRON VI [6] .. gm DUMPED III in 2006.. old GM died in 2008 lost billions ,,,. because of recall failures. now if the transmission works after the fluid change .. then change the fluid again after a few hundred miles. valves in the tranny stick ..I used transmedic additive on my old GM vehicles no issues. ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Tags
problems , s-10 , transmission
