Register FAQ Social Groups
Old 08-24-2007, 04:47 PM
vinnym86's Avatar
vinnym86 vinnym86 is offline
Send a message via AIM to vinnym86
Question Problem: extremely low revs at idle
I have a 1993 automatic Civic with close to 205,000 miles on it, and its finally showing its age.
Today, at a red light, the rpms dropped close to 0, and the battery light started flickering. The engine temp read completely cold, as if the guage was not even working, and the car itself was vibrating quite a bit. I was scared that it would just stall out, so i put it on neutral, and held the gas down til the revs raised to about 1,500-2,000, til the light was green. Got home, and before killing the ignition, same problem. 5 minutes later i fired her up again, just to make sure she started, and all was fine for the first 20 seconds, before the revs dropped right down to near 0 again...
whats wrong?
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
Old 08-24-2007, 08:29 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Problem: extremely low revs at idle
could be a misfire, could be the ignition timing jumped, could be the timing belt jumped. Plugged EGR ports and a sticking EGR valve is also common. Vacuum leaks are another possibility
Thats a short list mind you
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 08-25-2007, 03:23 AM
vinnym86's Avatar
i'm a dunce when it comes to the technical works of cars, i'm sorry. I'll bring this up to my mechanic, but, would there be a way i can solve this problem myself with some research?
Old 08-25-2007, 03:34 AM
AF -Advisor
No simple solution, sorry. They are all guesses without diagnostics. And guesses are worth what you pay for them. (that be zero)
Old 08-25-2007, 03:41 AM
vr4GTO vr4GTO is offline
whats wrong?
make sure all your tubes and all the vacuum line's that go from your air filter to your throtal body are still attached
Old 08-25-2007, 11:12 AM
INF3RN0666 INF3RN0666 is offline
Ok. The easiest thing ANYONE can do before you take your car into the mechanic's is to check the alternator charging level.
So bust out your multimeter (voltmeter) and check the voltage on the battery when the car is running. It should read 14.4 volts plus or minus 0.4. Otherwise, your alternator is dead, and your car is sputtering because it's getting very low voltage off the battery. Hence, it'll run ok for 20 seconds, then the battery is exhausted and the car acts up.
Other than that, you can't do much diagnostics other than test ignition wires by swapping them with new ones.
Old 08-25-2007, 01:00 PM
vinnym86's Avatar
thank you for the help everyone, I'll test the battery out today. If the alt is not the problem, then I guess its good timing to fix up the car, as inspection is next month anyway.
Old 08-28-2007, 03:12 AM
vinnym86's Avatar
I tried to test the battery today. With the ignition off, it read about 14.2v. Went to start the car, and it decided to start for only half a second before stalling, and never starting again. My dad thought it was just a discharged battery and gave a jump with his car, but it didn't do anything. My lights/radio/clock all still work. The starter motor is working, so i dunno wassup.
