Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 10-25-2007, 10:25 PM
bfry10 bfry10 is offline
1995 Berretta rough idle intermmittent after warm up. hesitatin upon accel
I have a 1995 Berretta 2.2. Great car! I am experiencing rough idle after warm up with hesitation upon accell at lower speeds and RPM. usuually be idleing along and will get intermittent hesitation example: riding in a 30 MPH zone and just cruising along.
Have ran codes. No code, No engine or service engine soon light but it does test. Ran codes with CP 9190 code scanner. Only abnormal thing I can see is quad driver 1 and 2 are reading bad on the scanner during drivability check.
Any help would be appreciated.
BFry10
BFry10
Old 10-26-2007, 07:49 PM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
Re: 1995 Berretta rough idle intermmittent after warm up. hesitatin upon accel
BFry10
you need a new e.c.m. quad drives are hard wired in the e.c.m. and cannot be repaired. quad drivers control, idle, fuel, shift points and a/c control at wot... check all your solonoids on the fire wall first, make sure there working right... ask me how many e.c.m.'s i have replaced and it worked perfectly after that, but i did check the firewall soleniods first and they have always been good except for one car and it still had to have a e.c.m....
Old 10-26-2007, 10:38 PM
Ok I cannot believe this but I went out this morning to start my car and ta daa, non start. I found that the fule pump was not running. I tried several times with no luck. I was just fooling around checking fuses on the fule pump control pwr circuit and turned on the key and I heard the pump run. I started the car. ran the car for 5 minutes and shut it off. waited 5 minutes and attempted to start again and wouldn't ya know it the car would not start and you could not hear the pump prime up. I am thinking fuel pump relay. The Haynes has a method of TS I will try in the morning. Will advise. Any other advise would be appriciated.
BFRY10
BFry10
Old 10-27-2007, 12:43 AM
loosenut74's Avatar
TS
???? what is TS?....
Old 10-27-2007, 04:16 PM
TS --- troubleshoot, troubleshot etc...
BFry10
Old 10-27-2007, 04:23 PM
I have completed the troubleshooting as per the hanynes manual and no go. I swapped relays and changed the oil pressure sensor/sending unit. (it was leaking a small amount anyway. $5.99 at auto zone)
RECAP: I have changed the ECM and all did not go well and seemed to get worse. I checked fuel pump relay and fuse. I went back and ordered another ECM. it seems that the wiring diagram dose have a cirsuit going through the ecm for fuel pump relay control.
So I will wait for two days to get another ECM. I had to order it.
If you guys and gals see something I am missing please pipe up and make it loud. I would appreciate it.
BFRY1 0
BFry10
Old 10-27-2007, 04:30 PM
loosenut74's Avatar
I thought you meant something like T.orch the S.on of a bish...lol...j/k... have you checked for power on both sides of the e.c.m.?... you know where the power comes in and then where it comes out, if you can get me and everyone here voltage readings that would help...
Old 10-27-2007, 11:54 PM
I was going to attempt to do that but my wiring schematics are limited tot eh hanynes manual. I will review and try but I have alrwady turned in the old ECM and I am waiting on the new one around Monday morning. I looked the the schematic before and located the fule pump control circuit. It was a D9 with green and white tracer. I did not see the exit point by the diagram. Haynes is very limited.
Is the voltage 12 volts or am I looking for control voltage only like +/_ 5 volts dc?
BFRY10
BFry10
Old 10-28-2007, 10:38 AM
loosenut74's Avatar
BFRY10
well if you have turned in the old one... it too late for voltage checks.... i hope and pray that all that was wrong with it was the e.c.m. but before you change any more parts...diagnois, diagnois, diagnois...
each circut will have its own assigned voltage ranges, im not sure what that one is suppose to be with out consulting Mitchells, but I'll check it when i get my Mitchells computer out of storage, but I believe its a 0-5 volt range...
Old 10-28-2007, 10:49 AM
I wish I had more technology to work with. If I just has information such as parameters,voltage values etc.. to work with I would be a lot better off. I do not run an automotive shop but I do take on some side work from time to time. Of course this is my work car I am attempting to repair now. Where can a fella get mitchells manuals at or DVD's. Are they expensive? Wel, Monday will tell. I work the 3 to 12 shift so I will pick it up tomorrow morning and install. Hopefully it will be good. I will update.
BFRY10
BFry10
Old 10-28-2007, 04:10 PM
loosenut74's Avatar
BFRY10
well you can go here and get some info...
http://www.ondemand5.com/
or here...
http://www.mitchell1.com/
video tour...
http://www.mitchellsupport.com/ondemand5/audiotour-v15/
Heres my rep, I live in Dayton,Ohio...
[email protected]
Old 11-02-2007, 12:23 AM
or here...
video tour...
[email protected]
It seems that the ECM fixed the issue. I was a more expensive route but it is runnning well. I accomplished another code scann and live data stream on the car and the #1 and #2 quad drivers are still readin as bad.
BFry10
Old 11-02-2007, 04:18 PM
loosenut74's Avatar
they still read as bad, i'll investigate it further, and get back to you... but that should have cleared it up... email me at [email protected]... I got some more info for you...
