Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 08-08-2007, 04:02 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
1967 283 chevy engine breather ?
I have a 1967 283 chevy engine in my 57 chevy and had a question about the engine breather in the rear of the engine. I think these were typically vented with a hose connected to the exhaust. I have since installed a pcv valve between the base of the carb and the vent and it seems to run fine that way.
My question is what would be the best way to vent the engine, with a pvc valve or ?.
Any suggestions would be helpful.
Thanks
Al
Old 08-08-2007, 04:19 PM
maxwedge maxwedge is offline
A990 racer
Re: 1967 283 chevy engine breather ?
With the pcv on there the vent pipe is no longer needed, unless you have excess blowby.
Old 08-08-2007, 05:36 PM
Blt2Lst's Avatar
So are you saying, keep the pcv valve setup.
Thanks
Al
Old 08-08-2007, 08:17 PM
A990 racer
If you have it set up, yes, but the vent tube set up must be blocked off for the pcv system to work as designed.
Old 08-13-2007, 12:07 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
The '67 blocks should have had those funky canisters under the intake manifold. Which always tended to get sludged up beyond belief. These were an improvement over the road draft tubes, not sure what the cut off date was for those, maybe 1961.
I think that you'll be ok with the PVC system too. Like Maxwedge says, block off anything that is open on the back of the manifold.
Bob
Old 08-13-2007, 12:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Bob
On a '67 327 that I worked on way back in the day, the PCV valve attached to the back of the block near the distributor (where the old vent tube used to be), it also had that sludgemagnet canister. The PCV setup was factory.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-13-2007, 11:32 PM
Blt2Lst's Avatar
Thumbs up Re: 1967 283 chevy engine breather ?
Thanks for the info guy's.
Al
