1994 Chevy temp guage doesn't work
I have a 1994 chevy 350, the temperature guage quit working a few weeks ago. Where is the sensor located on this engine? Should I look at wiring, bad sensor, or bad guage? I'm not sure where to start because I can't tell which sensor on the engine is the temp sensor. Thanks for the help!
Bob |
Re: 1994 Chevy temp guage doesn't work
The sending unit for the temp gauge should be on the drivers side of the block between the #1 & #3 spark plugs.
2006 VW Jetta TDI Diesel (Super fuel mileage) 2004 Chevy 2500 6.0 Crew Cab 1993 Chevy K1500 5.7 (love this truck) |
I don't see any obvious problems with the sending unit or wiring, is replacing the sending unit my best bet here? What about the dash gauge, do those go bad very often?
you could ground the wire going to the sending unit--I can't remember on 1994, but the gauge will go to either all the way hot or all the way cold when you ground the wire with the key on. If it moves one way or the other then the gauge is usually okay.
Thanks jocat54, I'll check the gauge to make sure it is working and probably replace the sending unit, I appreciate the help!
