![]() Join Date: Aug 2006
1999 Burb Front A/C not cold
My rear air blows COLD. Front.. not so much. What should I be looking to replace/test?
AF - Advisor
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Re: 1999 Burb Front A/C not cold
Auto or manual AC controls?
First make sure it has a good R-134a charge. With compressor jumped and running post back you low and high side readings at idle and at 2K. With a ac recharging gauge set. Like one of these. http://www.ackits.com/merchant.mvc?S...erantGaugeSets Low side should be close to 30 lbs. If it is dropping under 25 lbs the switch will cycle or shut off compressor.
Manual controls. Charge is good. Stays in the "green" zone on the Artic Freeze tester/filler from Autoparts store. Goes to the top of the "charged" zone and cycles off then drops to the bottom of the ''Charged" zone then cycles back on. At idle in 95 degree heat the compressor stayed cycled on & running great.
Without the $90 gauge set, does the above info help? 99 Suburban 144,000 mi. 2500 7.4L 4X4 K&N, Headers, 3" Exhaust |
Could it be the Temp control door? When did this problem start? Have you done anything that could coincide with the start of this? Can you turn the front temp control to hot and back to cold and feel the difference? Is your Sub a new body style or old body style '99?
Ah, so many ?'s.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
AF - Advisor
We really need some good accurate gauge readings at idle and at 2K RPM.
What is low side lbs reading at idle and at 2K? What is vent tempt on rear and front air? Is the low side inlet pipe cold on front air? Have you added any pure R-134a? Or any of the stop leak and any oil stuff that comes with the Death Kits? If it has a good charge the low side should range around 30 LB low side with compressor running. At Idle it is normal for low side to climb up 5-10 lbs up over 30 lbs. At 2K or on the road Low side should go back down to 25-30 lb range and cycle on and of some. At around 25 lbs low side it will cycle off and then at around 45 come back on.
I've got the same issue with my 99 burb. check the recycle switch and door and temp control door for proper operation. If the system is holding freon in the reccommended range/pressure, and the evaporator is iced up or freezing cold then the problem is the temp control door or recycle door. there is no reason other than that for the front to blow warm and the back to blow ice cold.
And if the evap is not cold replace it........ |
#7 | ||
AF - Advisor
Unless the evaporator is leaking there is no reason to replace it. MT
#8 | ||
Could be clogged!!! |
#9 | |
thanks for all the advise!
Where/how do i check the control door for operation and /or check the evapoator for cold/freezing? There was nothing done to the rig before this started happening. Thanks again, hopefully this will help someone else too. I got a set of gauges, will check today hopefully and post the numbers. |
#10 | |
AF - Advisor
Could be yes.
But in the last 45 years of working on AC I never did see a evaporator clogged/stopped up inside. MT
Remember proper testing gives us the answer to many problems. MT Last edited by MT-2500; 07-14-2007 at 08:42 PM. |
#11 | |
OK, here are the readings
Low side at idle 32psi. High side at idle 160 psi Low side at 2000rpm 18psi to 50psi back and forth High side 125psi to 160psi back and forth |
#12 | ||
Once again, new body style or old body style?
#13 | |
Will check those things. Old body style.
Thanks for the help! |
#14 | |
Ok, tested the vent door operation. Turned to hot, it heats right up, turned to max air cold, cools down right away but only cools to 71 degrees front vents but 54 degree rear vents. It is 74 degrees outside air temp.
#15 | |
could the dryer have anything to do with it just curious...
