98 Dodge Caravan 3.0l tranny problem
On my way back from droppin the kids off at the grandparents for a visit I noticed my tranny seemed stuck in 2nd gear on the highway, I had to hit the gas hard and then after stopping the accelerator it would sometimes shift into third. As i got closer to home, I noticed that the transmission would not "release" the engine when coasting. Like when you use your engine to brake in a manual transmission, it would quickly slow down the vehicle staying in gear, though once vehicle speed dropped enough (less than 20mph or so) it would function normally. Not quite sure what to make of it, sounds like it's entering limp mode, but the rest of the behavior (aside from the not going above 2nd gear) confuses me. It had a fluid flush/fill about 3 months ago. 108k miles on the vehicle, it has the 3 speed (no overdrive) transmission. Any idea's on what I should look for? I'm not a car expert, but I can diagnose and repair if I have an idea of what to look for. thanks^^
Re: 98 Dodge Caravan 3.0l tranny problem
You had the trans flushed. I hope they used ATF+4 fluid, and a new filter. The wrong fluid, or not replacing the filter, can cause trouble down the road.
If it's not the Overdrive 4 speed, then being stuck in 2nd all the time is likely a stuck 1-2 valve, or stuck governor. If it's an overdrive trans, then there's a TON of things that can cause limp mode. |
they used atf+4 and replaced the filter, so you think either the 1-2 valve or the governor, any way to test those? aside from throwing a new one in of course
edit: Took it to schucks to have the codes checked (as advised my bro) there were no codes, and it was slipping in 1st gear (like a bad clutch on a manual) it was suggested that it may be the bands in the tranny, which sounds like an intensive repair. Last edited by vanicent; 06-29-2007 at 09:02 PM. |
There is a simple band adjustment that can be done, but it requires tranny pan removal, I'm no expert on what can cause the funny shifting, but if it is a band adjustment, I know it is simple if you have the specs and a torque wrench.
Only the electronic, 4-speed automatic (P-R-N-D-3-L) has limp mode and readable codes. There is no band adjustment on these transmissions, either.
Sounds like you have the 3-speed automatic (P-R-N-D-2-1). First of all, check the fluid level. This is most accurate with the transmission hot and the engine idling in Neutral. Top off as necessary but don't overfill. Transmission fluid expands as it gets hot, so what might look slightly low when cold may actually be full when hot. The transmission contains two planetary gear sets, the front and the rear. Each gear set has a hydraulic clutch (the front clutch and the rear clutch) and a band around each hub (the kickdown/front band and the low/reverse/rear band). The rear hub also has a static, one-way sprag clutch that holds the rear hub. The bands are adjustable. The low/reverse band adjustment is located inside the transmission case. The kickdown band adjustment is located on the outside of the transmission case. The mechanic who changed your transmission fluid and filter should have adjusted the bands at the same time. If they did not, they are a knuckle-head. Next, try a functional test in each gear. Reverse - this gear requires the engagement of the front clutch and the low/reverse band. If this gear operates normally, the front clutch and low/reverse band are fine. If not, one is the culprit. Manual Low (1) - this gear requires the engagement of the low/reverse band and the rear clutch. This gear should not slip during acceleration and provide engine braking when you let off the accelerator. Slippage here indicates a worn out rear clutch pack. No engine braking indicates a loose low/reverse band. Slippage on acceleration and no engine braking indicate both are a problem. Also, low gear, whether manual low or "drive breakaway" low, always makes a distinctive whine that the other gears don't. Manual Second (2) - In this gear, the transmission starts out in drive-breakaway low. This is engagement of the rear clutch and a holding of the rear hub by the sprag clutch. Drive-breakaway low differs from manual low in that the low/reverse band does not engage and there is no engine braking in this gear. The second gear range requires the engagement of both the rear clutch and the kickdown band. It will shift into second by engaging the kickdown band and hold in this gear. If you have slippage in drive-breakaway low and second gear, the rear clutch is the problem. If low is fine, but second gear slips, the kickdown band is loose. If there is no engine braking in second, again the kickdown band is loose. Drive (D) - It will start out in drive-breakaway low as above, shift to second as above, then shift to high gear. High gear requires engagement of both the front and rear clutch packs only. When it shifts to high gear, the kickdown band releases and the front clutch engages. If you have slippage in this gear only, the front clutch is the problem. Now for the quick and dirty: If the front clutch is bad, you will slip or not engage in reverse and high gear. Replacement of this clutch pack requires a rebuild. If the rear clutch is bad, you will slip or not engage in all forward gears. Replacement of this clutch pack requires a rebuild. If the low/reverse band is loose or worn, you will slip or not engage reverse and you will have no engine braking in manual low. Adjustment of this band may cure the problem. If unable to adjust, a rebuild is required. If the kickdown band is loose or worn, you will slip or not engage second gear only. Adjustment of this band may cure the problem. If unable to adjust, a rebuild is required. Check your fluid again, do the functional test and let us know what you find.
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
KManiac, Thanks for the diagnosis method. I have one of these beasts, and I am going to bookmark this post for future use.
