Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 04-06-2010, 09:40 PM   #1
3nas8car8
Power Window issues
All 4 of my Power Windows don't work and i checked the fuses in the fuse box in the glove box and they all look good, the windows won't work individually or by the main panel in the drivers door.I keep hearing about a fuse box up under the hood but i haven't found it so can someone plzzzzzzz help me with this, summer is coming and i cant afford to run the A/C all the time.
3nas8car8 is offline   Reply With Quote
Old 04-07-2010, 07:43 PM   #2
CutlassOlds88
Re: Power Window issues
what year and what kind of car?
1988 Oldsmobile Cutlass Supreme
1991 Oldsmobile 442 W41
1998 Oldsmobile Bravada
CutlassOlds88 is offline   Reply With Quote
Old 04-10-2010, 07:08 PM   #3
3nas8car8
Sure can tell i'm a newbie at this lol....It's a "91" Ciera 4 door base model nothing fancy, can't afford fancy right now, just a hoopty for back n forth to work.
Old 04-10-2010, 10:27 PM   #4
Ralph123
Ralph123's Avatar
I would double check your window fuse again. Try a new fuse or switch the fuse with another one.
Do you have the owners manual for your ciera?
Ralph123 is offline   Reply With Quote
Old 04-11-2010, 10:04 PM   #5
JohnDD
Likely a broken wire in the driver side door hinge area. If a ground is broken, all the windows won't work. Easiest way to check is to take the rubber protection (tubing) out on both the door side and the body side and pull on each wire. A broken wire will stretch. Fix it by splicing in a new piece.
I had this problem several times on my 91 Cierra before I scrapped it.
JohnDD is offline   Reply With Quote
Old 07-13-2010, 01:17 PM   #6
dsamsonb522
def the wire in the drivers door i had the same prob u got to be carefull when splicing these wires so your not too short i used a hot glue gun as a protecter after fixing the problem it reallyt works
dsamsonb522 is offline   Reply With Quote
