Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Register FAQ Social Groups
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 05-04-2007, 12:34 PM
benie benie is offline
any step-by-step on changing the front axel??
does anyone know of any info on step-by-step to changing the front axel?? online or if you know how and you can help me?? any help will be appreciated!! thanks!
-benie
Old 05-11-2007, 07:50 AM
BullShifter's Avatar
BullShifter BullShifter is offline
Re: any step-by-step on changing the front axel??
It's simple
Remove wheel
Remove axle nut - may be very hard without air tools
Remove lower ball joint nut
Pop out lower ball joint either by hitting the lower control arm with a hammer near the joint or use a pickle fork
Remove lower strut bolt
Push axle out of hub by pulling on brake caliper and pushing axle in
Pop out axle from trans
Remove axle from suspension by pulling down on lower control arm
