Go Back   Automotive Forums .com Car Chat > Buick > Buick Classics
Buick Classics Discuss older classics here.
Old 01-17-2007, 04:05 PM   #1
Buickspec6231
Send a message via AIM to Buickspec6231
Buick Axle Swap
Hello, I am new to the Forum. I have a 1962 Buick Special. I have done an engine swap. I swapped in a later model 231ci V6 with hopes of later finding a Turbo Engine. In order to do this I had to modify the front crossmember, the center link, fabricate a new transmount, new motor mounts, modify the tranny tunnel in order to clear the larger TH350 over the Dual Path. So I have done lots to it, with lots more to go before it is on the road. So far, I haven't found any information regarding axles. The axles now, as well as the front spindles are 4-lug, but everybody knows, all the best looking wheels are five lug. I want to change out the rear axles as well as the front spindles inorder to fit a nicer 5-lug pattern. Does anybody know what parts will interchange or has anybody already done this. I do not want to use wheel adapters to do this, I want to do it right. Thanks.
Buickspec6231 is offline   Reply With Quote
Old 03-21-2007, 07:58 PM   #2
69-87-95-buicks
Re: Buick Axle Swap
Try searching these sites, anything can be done with enough time and cash $$. Good luck with your project, sounds interesting!!
http://buicks.net/index.php
http://www.v8buick.com/
Find user with name "oPh", he seems to be the rear axle expert on v8buick.
69-87-95-buicks is offline   Reply With Quote
