Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 01-13-2007, 12:59 PM
itsah2 itsah2 is offline
Problems with Remote Starter Installation
I have a 2002 Chrysler Sebring Convertible that I've been installing a remote starter in for the last two weekends. I went to finish up the installation this weekend, but when I tried to start the car (with the key) to move it out of the garage... it wouldn't start. I haven't been using the car during the week but it has started fine with the key for the past two weekends.
When I try to start the engine, it starts to turn over, then stops, and then starts making a rapid clicking noise over and over. My friend suggested it was an anti-theft measure, but I don't see how that would be the case since I am using the actual key.
Has anyone installed one of these before on a Sebring, or know what could be causing the problem? Thanks a lot.
Old 01-13-2007, 01:28 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Problems with Remote Starter Installation
All symptoms you mentioned, points to a weak or dead battery. Check battery voltage, it should be 12.6 to 12.7V.
Knowledge can be communicated, but not wisdom!
Old 01-13-2007, 02:09 PM
I'll check that ASAP, thanks a lot.
Old 01-15-2007, 08:39 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
I don't think so. If it cranks and starts then stalls, you have something else going on. Is the red dot for the security light flashing??? How or what did you use to bypass the Sentry Key? Sounds to me as if the car is seeing two key codes.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 01-15-2007, 10:14 PM
The car does not completely start. The engine begins to turn over for maybe half a second, then stops, and proceeds to make a clicking sound until I stop trying to crank it. The engine does not run at all. Testing indicates a battery problem; I was going to try to jump start it to avoid buying a new battery but I don't know if there's any reason I shouldn't...
I don't think its an anti-theft problem because my car does not have a Sentry/Transponder key. From my understanding transponder keys are the thicker, gray keys; mine is a thin, black key. The car does not have any kind of anti-theft system to my knowledge.
Thanks again for any help.
Old 01-20-2007, 01:56 PM
I got the problem resolved. Turns out the problem was with the battery; it was dead all along, I don't know why it started with a key originally. The remote starter works fine now also. Thanks for everyone's help.
