clutch noise
ok it doesnt seem to be anything serious but i dont know if it could get serious because it wasnt there when i got the car and its on warrenty so if it could become a bigger problem i wantto talk it to honda.
at a certain point when im pushing and releasing my clutch i here a click its not the gear engaging its just a lonley clicking noise. 99 civic 2 door. whas up any one got any imfo on it? please. |
If it is a quiet click your hearing it is more than likelly the clutch start switch this makes the car so it doesnt start without the clutch depressed
Like he said its either the clutch safety switch or your it can be a number of things. It could most likely be your throw out bearing that has broke a bearing inside of it making it click or it coiuld possibly be the clutch fork hitting something or the throw out bearing spring. Puit your head under the pedal and see if you can direct where the noise is coming from when your head is under there. If its not from under the the dash then check and see if its a relay. Have someone jump inside and go under the hood and see if any of the relays are clicking when you push the pedal in. Hope that helps!!
~Alex~
VTEC WORKING FINALLY & HAULIN SOME ASS!! If the shadow of your car is smokin' you it definately means you are smokin' someone else!! KKK k24 Turbo on the way to the install! |
Re: clutch noise
Hey bro well i had the same problem. When you press all the clutch in and let it go a little thats when you here the noise right. What happents when you put first gear does the noise come louder. Well mi problems was that the flyweel was loose so i think that you should take a look at it. When you take down your tranny. Take down your clutch and check it out. |
