Register FAQ Social Groups
Old 12-13-2006, 06:06 PM
MooseNelson's Avatar
MooseNelson MooseNelson is offline
Little Red Straw has entered throttle body!!
I mean I read the articles about making sure that stupid straw doesn't fly out when cleaning the throttle body into the intake, but this BEEATCH went shooting right in!
I remove the throttle body itself but still can't get at the intake enough to fish it out, it's fallen down one of the intakes (i can still see it, but feel screwed)
how much will this create havoc? Seems like those chambers are dirty enough that a little red plastic wouldn't be the end of the world
g
http://www.georides.com
Sub Compacts, Electrics, Biodiesel, hydrogen
Old 12-14-2006, 12:21 AM
bluevp00's Avatar
bluevp00 bluevp00 is offline
Re: Little Red Straw has entered throttle body!!
well...if it did get sucked into the engine it could be hit by the valves. There are two outcomes here: 1. The valves hit the red plastic and shatter it [the plastic] to peices, vaporizing it in the cylinder. or... 2. The valves hit the red plastic at such a high speed that the valve cracks/chips.
If #2 happens then you might be in some trouble. If you can still see it, then try sticking a wad of duct tape to the end of a stick and try to fish out the red peice.
Old 12-14-2006, 08:56 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
go to a store that sells plumbing stuff, and ask for a thing called a Pearl Catcher. you get either rigid or flexible ones. get a flexible one. it's like a hollow tube with a "handle" at one end. you push a button on the end and 3 little "claw" come out the other end. as you release the button, the claws grip. if you can see the thing, you can carefully use the pearl catcher to get it.
Seatbelts Saved My Life
Old 12-14-2006, 10:53 AM
534BC 534BC is offline
I doubt the plastic straw will cause a problem.
Old 12-14-2006, 12:28 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
It will not cause any problems.
Them things are soft plastic and will melt when the engine get hot.
But as said if you can still see it they make tools to grab it.
Good luck
MT
Old 12-15-2006, 07:24 PM
Amigos,
Thanks for the replies, well I've been driving up to boston and back with no problems, most likely it's vaporized, but what a drag.
I like the duct tape idea, thanks
pearl grabber....that's the name!
Old 12-15-2006, 07:29 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
I got a move I call the pearl grabber... but um.. its not related to cars.
