Trans Modulator
After doing a bit of research, I think I may need a new trans modulator. The symptoms my car is having are - banging into reverse, sometimes it's worse than others, and hard shifting from 1st to 2nd. The first thing I did of course was check the fluid which was fine.
My question is, right about the same time the hard shifting started my car began to idle rough. Not consistently though. It will idle just fine, then get real lopey almost stalling but it'll catch itself and idle fine again. This happens while in Park and sitting at a stop intermitently. Are the two problems related? Thanks for any advice.
chris 92 Bonneville SSEi ![]() |
Re: Trans Modulator
Fix engine running first. Modulator valve is not going to help muck on reverse. It controls the pressure more on up shifting. On a normal take off what is the 1-2 2-3 3-4 up shift MPH speeds?
Re: Trans Modulator
Hey Chris
I have a problem with my 93 SSEI running rough if you get yours fixed please tell me what you did to fix it. dewey [email protected] |
Re: Trans Modulator
Check your modulator for a vacuum leak first.
2010 Mazda CX-7 2.5L 12000 miles 2003 Chevy S10 Extreme 4.3L 57000 miles 1995 Buick Lesabre Custom 86000 miles RIP 2002 Pontiac Sunfire SE 130000 miles RIP 1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!! R.I.P. 1978 Ford Fairmont 83000 miles
Re: Trans Modulator
What may fix the Gander may not be good for the Goose. Start a new post on yours and some one may be able to help. And give all info like. Tips on getting a good answer to your questions. People trying to answer your question do not have a crystal ball. So give them all of the info you have like year make and model and engine and transmission and mileage. Also cars engine and transmission service history or any recent repairs or problems. Also a description of your problem and what it is doing or not doing. If you have codes give up the code no. And remember a code does not say replace the part but only points to the problem that you have to check out. So to better help you give up all of the info you have on it. MT
