Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-04-2007, 10:55 AM
stillmanm stillmanm is offline
Truck is flooding when i step on the peddle
I have 97 GMC Sierra 2x2 6 cyl truck. The truck will start and sounds great at idle and even runs fine with a little pedal but when you rev it either while in park or driving it floods and boggs down. Any idea what this may be. I know the fuel pumps on these things go often but would this be a fuel pump issue. Thanks for any and all help. Mark
Old 01-04-2007, 11:21 AM
Low-Low-SIERRA Low-Low-SIERRA is offline
Re: Truck is flooding when i step on the peddle
I am having the same problem. This started after I changed the fuel filter.
Thanks in Advance.
Old 01-04-2007, 03:34 PM
Stillman. I'm having my fuel pump changed as I speak I will let you know if that is what caused the problem.
Old 01-04-2007, 05:47 PM
maxwedge maxwedge is offline
A990 racer
I'd have the fuel pressure tested and check the cpfi unit for a bad press regulator or bad injector poppets, common problem with the Vortech.
Old 01-05-2007, 09:53 PM
E B E B is offline
My 97 with the5.7 acted like that it was the fuel pump. Funny thing happened with pressure test it had 60 p.s.i but when I tried to accelarate fast it would bog down. I changed the fuel pump it ran normal. I was told it had enough pressure but not enough volume.
Old 01-07-2007, 11:32 PM
So I took my truck to get a diagnos. It gave me EGR sensor and the Air Mass flow. So I replace them and truck is still doing the same. I took it back to the place I did the diagnos and did the diagnos again and it gave 2-4-5-7 pistons are mis firing.
The mechanic said to change the distribiator cap wire's and plug and this should make the truck run normal.
What do you guys think should I do this?
Thanks in Advance.
Old 01-08-2007, 08:36 AM
E B E B is offline
Try the lowest cost fix first,my truck would idle fine , but when I tried taking off fast it would stumble. I could get to highway speeds if I eased into it.
Old 01-08-2007, 08:53 AM
E B E B is offline
By the way when it was doing all the stumbling it was the fuel pump. Now I just had a problem with misfire at no 4 and the intake gaskets were bad
E B E B is offline
Old 01-08-2007, 09:39 AM
A990 racer
Exclamation Re: Truck is flooding when i step on the peddle
Thanks in Advance.
Sure let them do this work with a written guarantee that this will fix it, if not you get a refund.
Old 01-08-2007, 10:39 AM
E B E B is offline
Good idea make them back their diagnosis
