| How-to | Technical Info A wealth of information at your disposal. |
Broken Hazard Switch Repair How-to
Don't think I ever posted this how-to here
Yes people, someone has finally done the Broken Hazard Switch repair because we were stupid when we pulled the dash bezel How-to!!! This applies to all 95 and up trucks Tools and Parts required: Parts: GM Hazard switch repair Kit part # 15174447 Cost= $15.00 to $17.00 at the dealership Tools: Needle Nose Pliers The hazard Switch kit will come with a small tube of dialectric grease. Smear this on the entire thing before installation. First look at your old hazard hole. You should see it broken similar to this. Reach in with your needle nose pliers and grasp the edge of the old switch housing and pull upwards and remove. You should now have the entire assembly out.. Now simply insert your new hazard switch in hole and push down firmly.. New Switch: And wala! You're done... Your final repair should look like this.. (though less blurry unless you're not wearing glasses then it will look just like this! Takes about 3 minutes. If you can't do this repair, you're a complete moron! Enjoy!
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal Last edited by blazee; 04-26-2009 at 05:32 PM. |
Problem?
![]() Join Date: Dec 2004
Re: Broken Hazard Switch Repair How-to
I was wondering when you were going to post it here.
Added to the FAQ. |
I call DUPE (propogated by the both of you) You are now guilty of plagurizing yourself. Got a link to a different forum,which was of great help. It's even got the same exact format and pictures. http://www.automotiveforums.com/vbul...d.php?t=558992
It's my opinion, don't take it personal. '04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC |
Problem?
It's been posted on several sites for a long time. It needed to be posted here because we're not allowed to link to other forums. The rules were a little fuzzy when I gave you the link, but now that the rules have been updated, its very clear that absolutely no linking to other forums is allowed.
#5 | ||
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
#6 | ||
#7 | |
![]() Join Date: Feb 2005
you guys should post this in the fact section.
#8 | |
I have a 96 blazer with a broken hazard and the dealers and wreckers all same the same thing... 95 96 97 all have to replace multi switch to replace hazard ...tey wont even sell the hazard sep. called gm they say same thing...hmmmmm
#9 | |
Problem?
They told me the same thing with my 98. You have to give them the part number and tell them to look it up. After they know that you know the part exists they will usually sell it to you. Otherwise, it's more profitable for them to sell you the $150 part vs. the $20 part.
#10 | |
ok that sounds like something they would do ...perfect do you have a GM part number for me..thanks a mill
#11 | ||
Did you even bother to read the very 1st message in this thread?
#12 | |
![]() Join Date: Dec 2003
I just purchased my 97 blazer and was in the process of removing the column cover and all.. then i gave up and found this thread... purchased the part listed and it worked perfect.. Thanks.. next time i will look here before i attemt a repair.
#13 | |
does the hazard switch also control the turn signals? cuz i broke mine today and the turn signals dont work either. im assuming the multifunction switch still works because my wipers, cruise control, brights, etc. all still work just not the turn signals. i found this thread really helpful thusfar in removing the broken one but still have to get the part. help???
#14 | |
Has anyone tried this on a 96 bravada? I have had a few shops and a dealer tell me that these are normally modules that can be replaced but in a 96 the entire steering column has to be replace...... im thinking they are yanking my chain. I found another way to fix it but every few months it acts up. I pushed the broken button down enough to where the hazards were off and the blinkers still functioned. Marked that spot on the broken off piece and drilled a hole through it. Then fastened it down with zip ties around the steering column.
#15 | |
Thank you very much. I just used this to repair the hazard switch my 98 Oldsmobile Bravada to fix the lights. The part number worked perfectly. GM would not sell it to separately me but Chevy (next door) had one in stock. Solved a long time problem with lights.
