Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-07-2006, 02:09 AM   #1
jbz3
Top Nut On McPherson Strut
I am trying to replace the strut on a 91 Cutlass Ciera. What is the secret to tightening the nut at the top of the McPherson strut? The rod just spins. I can't get a socket on the nut and hold the rod at the same time. Is there a special tool or a secret to accomplish this? Thanks for any suggestions.
jbz3 is offline   Reply With Quote
Old 10-07-2006, 02:12 AM   #2
alphalanos
Re: Top Nut On McPherson Strut
You could get some thick rubber padding like those things used to open jars and clamp the shock rod with it.
-Just make sure its very thick so you dont scratch the rod.
96 EJ6. Future home of boosted B18C1.
alphalanos is offline   Reply With Quote
Old 10-07-2006, 02:23 AM   #3
jbz3
Thanks for your reply however only the top end of the rod is visable. That is the problem. The top of the rod has flat sides to grab but the nut is below it. So if you have a socket on the nut, the top of the rod with the flat sides is buried inside the socket and you can't get to it. There must be a simple trick to it as shops do this all the time. I just cant figure it out....thanks again
Old 10-07-2006, 09:53 AM   #4
alphalanos
Maybe use a box wrench?
Old 10-07-2006, 10:09 AM   #5
jbz3
I tried that too. The nut is down in a recess so you cant get a box or offset wrench on it. I can barely get vice grips on it and tried turning the top of the rod with a wrench. I was able to get it to get the to spin a little but not nearly as tight as it needs to be. I can't believe they make this so difficult for a 'do it yourselfer'. Thanks again for any other suggestions!
Old 10-07-2006, 12:57 PM   #6
mediocre george
The typical method is to use an impact wrench on it. If you don't have access to one, I'd say get the nuts on as much as possible, and drive it to a shop (no way the struts should come out or anything), and see what they would charge to get them on for you. shouldn't be much.
mediocre george is offline   Reply With Quote
Old 10-07-2006, 02:54 PM   #7
jbz3
Thanks a million for the help everyone! I took it downtown to a local shop and they hit it with the impact wrench and that cranked it right down. No charge either! I really appreciate the replies and suggestions!!!!! Thanks again!
Old 10-07-2006, 06:26 PM   #8
mediocre george
Couldn't have asked for that to work out any better! Glad it worked out for you man.
George
