Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-29-2006, 01:42 PM   #1
Mikelb
Mikelb's Avatar
Send a message via AIM to Mikelb
Iridium or not to Iridium
I just took possession of my Talon last night... but I noticed it seems to have awful idle (No CEL) and a slight miss...
I know the battery is dying (car has sat awhile)... but I was told it has iridium plugs in the car... I have heard that these are terrible for DSMs...
I think it's time to change them...
The car is boosting 17psi on the stock turbo... what plugs should I get(same or 1 range colder)... and what gap should it be set at?
look at my sig for other mods...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Mikelb is offline   Reply With Quote
Old 08-29-2006, 03:33 PM   #2
l_eclipse_l
l_eclipse_l's Avatar
Re: Iridium or not to Iridium
Iridium is OK, but not preferred. It works better in the N/T cars.
Get some NGK BRP7ES and gap them to around .028, and you should be good to go.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
l_eclipse_l is offline   Reply With Quote
Old 08-29-2006, 11:24 PM   #3
kjewer1
AF - Advisor
Platinum is what turbo car owners should avoid like the plague. Iridium is definitely ok. The EVO comes stock with NGK iridium 7s. They aren't really necessary though, mainly just good for longer life than copper plugs. Copper plugs are so cheap though, we should really all just be swapping them every 1 or 2 oil changes anyway. I run colder plugs, so I change them every 2500 miles with the oil. Only like 7 bucks for 4 of them, especially if you buy by the case. NGK BPR7ES should be right up your alley, with a 028 gap.
Edit> Just noticed eclipse already gave the plug type and gap info
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
kjewer1 is offline   Reply With Quote
Old 08-30-2006, 12:35 AM   #4
l_eclipse_l
lol....
'92 3000gt SL
Zoom Stage 1 Clutch
Old 08-30-2006, 08:31 AM   #5
Mikelb
Mikelb's Avatar
Well you guys, u just affirmed each other, so I feel more confident in the plug choice ... I was actually getting iridium and platinum mixed up... I was fearing for my dsm... lol... I don't feel so bad now though, I do think I have spark blowout though... b/c the car will boost up to say ~14 and then the car tops off... then I usually shift and let it blow off...
Old 08-30-2006, 02:25 PM   #6
defiancy
Stay classy San Diego
defiancy's Avatar
Also, I was using some Denso's for a while and they weren't seating correctly with my plug wires, it's happened with another brand of plugs before. I only use NGK plugs and wires now because of the fit.
When I had those crappy plugs on there my car was doing some of the same things yours is doing.
1991 GSX 2.3 Stroker
defiancy is offline   Reply With Quote
Old 08-30-2006, 02:25 PM   #7
defiancy
defiancy's Avatar
Old 08-30-2006, 02:32 PM   #8
Mikelb
Mikelb's Avatar
yeah, I talked to the guy, he drove it on 87 gas just long enough to get it to the shop (~20miles) and thinks that might've fouled the plugs... that or the car's hitting fuel cut... I always puss out when it does it, b/c I don't wanna mess the car up...
hey, pm me with paypal details and pics on that BOV... I want a different one (crushed stock for now)...
Old 08-31-2006, 04:45 AM   #9
Thor06
Jizzed In My Pants
Thor06's Avatar
I dont think spark blow out is the reason to avoid platinum in a turbo car. Turbo cars make much more heat than NT engines and IIRC it actually melts the soft platinum and it drips down into the cylinder.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Thor06 is offline   Reply With Quote
Old 08-31-2006, 08:17 AM   #10
Mikelb
Mikelb's Avatar
No, I was meaning that I thought my (Iridium) plugs were blowing out... but that was incorrect... the BOV was messing up and not holding boost...
When they put the car back together, the vacuum hose on top of the BOV never got reconnected...
The car wouldn't boost over 10psi... put that hose back on, and the car's fast as hell
Old 09-01-2006, 10:23 PM   #11
ez1286
ez1286's Avatar
Send a message via AIM to ez1286
My brother had some problems with iridiums in his 2g, it was only under WOT, he replaced both coils and wires several times, then replaced the plugs with some more iridiums and still had the same problem, at one pint someone suggested it was the iridium plugs. He switched them out for stockers and the problem was gone. It could have been the manufacturer though because he used the same one twice but i don't remember what brand it was. I feel iridium is pointless in reality, if it does work it's not worth the cost ($40 for a set vs $8 a set)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
ez1286 is offline   Reply With Quote
Old 09-02-2006, 12:21 AM   #12
l_eclipse_l
I paid like $27 shipped for a set for my car...still like 3x the cost, but oh well they last a lot longer and I think it improved my gas mileage a little.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-10-2006, 06:17 AM   #13
kjewer1
AF - Advisor
The problem with the iridiums may have been the gap. They are difficult to gap properly due to the nature of the plug. I ran them on the EVO down to 12.0 at 114, they seem to work fine for me. Who knows.
Kevin Jewer
Old 09-10-2006, 06:54 PM   #14
ez1286
ez1286's Avatar
I wasn't disagreeing with you, i was thinking about that and i wonder if the evos had a higher charge for their spark. The plug my brother had were pre-gapped.
Old 09-11-2006, 06:25 AM   #15
kjewer1
AF - Advisor
I've never seen a pregapped plug that I've been able to use. I always have to close the gap some. Most plugs are pregapped for NA cars. But if it was pregapped to the right value it may have been something else. I defintely wouldn't say that the EVOs have better spark either, crusty old 1g coils/ignitors are a big upgrade for the EVO! Go figure. I'm ont disagreeing with you either, just thinking out loud.
Kevin Jewer
