Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 08-15-2006, 12:04 PM   #1
veedbya
Send a message via AIM to veedbya
Faulty AC switch?
anyone ever have a faulty AC switch?
I have 96 Tacoma and drove it about 9 hours one day with AC working fine the whole time. The next time I turned it on, the light came on, but there was no cold air and I realized the compressor was not running. According to the owner's manual, the AC light is supposed to flash if something in the AC system is bad, but it was not flashing.
Before I checked anything else I checked my Haynes manual and it says to check the AC switch for continuity, which I did and I only get continuity on terminals 1 and 3 of the switch, but nowhere else with switch on or switch off. Is it really that simple that it is just the switch?
veedbya is offline   Reply With Quote
Old 08-15-2006, 12:53 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Faulty AC switch?
Pitch that haynes manual in trash can and get some good info. Like factory service manual or all data DIY.
http://www.alldata.com/products/diy/index.html
Look at the wiring diagram and make sure you are getting 12 volt power to right places.
Lot of computer and module controls on it and do not try to jump the 3 or 4 wire pressure switches.
First thing would to check check all fuses on it.
Does the fan blower work alright and the heater part work good?
MT
Old 08-15-2006, 01:18 PM   #3
veedbya
well it figures, my all data diy subscription ran out last month and i didn't renew. but i did check all the fuses and they are ok. the blower and heater part work fine.
Old 08-16-2006, 05:53 AM   #4
Flash75
AF - Advisor
Did you look to see if the compressor is turning? It has a belt, it's may have broken. After checking the simple obvious things you are going to need an AC manifold gage set. If you don't have a gage set you will probably have to visit the dealer or a repair shop that does AC work.
Clifton
Flash75 is offline   Reply With Quote
