Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 05-02-2003, 03:35 PM   #1
bweera
Angry 1990 735IL coolant temp problem
I have this annoying over heating problem with my 1990 735 iL.I replaced the leaking water pump, fan clutch, thermostat and all the drive belts. Bleeding the coolant helps to maintain the heat gauge needle right in the middle for some time and overheat again.Could any one help?:o
bweera is offline   Reply With Quote
Old 05-03-2003, 08:06 PM   #2
jay76silver
you still can try couple things: first check radiator, it might be pluged and second is radiator cap. it doesn't keep preasure so you lose antifreeze and engine overheats.
jay76silver is offline   Reply With Quote
Old 09-16-2005, 10:08 AM   #3
donriko
Re: 1990 735IL coolant temp problem
buddy check to make shure your auxilary fan is working go to
www.nmia.com/~dgnrg/page_2.htm
if that dos not work you have to do what i did cry because you blew a gasket you will need to get the hesd gasket replaced while your at it a valve job i did and have no more problems call me for more info riko 561-310-8800 i had same headache as you do i now yhe feeling
donriko is offline   Reply With Quote
Old 07-21-2006, 05:49 PM   #4
Helmer Salmeroni
Must be simple.... you might not have the proper coolant antifreeze, or mixed, or too much water. Flush your sistem like two times, then replace for the original BMW antifreeze or just green... NOT ORANGE....!, use the car for a few miles and flush again..... Let me know if that works
Helmer Salmeroni is offline   Reply With Quote
Old 07-29-2006, 07:40 AM   #5
dlog
After bleeding how long until it overheats again? Have you ever let it overheat really badly? I hate to say this but, if the system continues to need to be bled either your not bleeding it right or you have a blown head gasket.
dlog is offline   Reply With Quote
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 01:14 PM
2001 Chevy Cavalier Coolant System Problem getwilde Cavalier Problem Diagnosis 0 09-18-2009 07:43 PM
coolant temp problem neoncruzier Neon | Plymouth Neon 2 03-04-2008 02:01 AM
735i coolant temp problem. viper2m 7 Series 3 06-28-2002 10:55 AM
