Go Back   Automotive Forums .com Car Chat > Cars in General > Shop Owner Advice
Shop Owner Advice Discuss various issues relating to running an auto shop with other shop owners/employees.
Old 02-16-2006, 07:05 PM   #1
jkloppi
oil in antifreeze
Just Bought a usea toyota, Looks like real dark antifeeze. I have heared of antifreeze in oil. Is it possible to get oil in the antifreeze. Any Ideas what to do. Thanks
jkloppi is offline   Reply With Quote
Old 02-16-2006, 08:17 PM   #2
MclarenF1
MclarenF1's Avatar
Re: oil in antifreeze
I'm afraid that finding oil in your antifreeze is a tell tale sign of a blown head gasket.
Keep in mind, though, that oil and radiator water will normally form a mix of green (or orange, or whatever color the antifreeze is) and marbled black. It would be an oil and water mix, after all. They would tend to separate like the oil and vinegar in Italian dressing. At least that's often the case, anyway. Your water MIGHT be dark just because you need a serious radiator flush.
If it is indeed a blown head gasket, there are other signs to look for:
Does the car run hot?
Does your heater work like it should?
And two sure signs of a bad gasket are:
Is there any wetness around the area where the engine head meets the block?
Is there any water in the oil when you drain your oil pan?
Good luck!
Fun times at the Auto X...
MclarenF1 is offline   Reply With Quote
Old 05-25-2008, 03:51 PM   #3
Tuffdrvr88
Send a message via Yahoo to Tuffdrvr88
Toyota comes from the manufaturer with a red extended drain coolant. Needs to be flushed at 30-40,000 miles. If you bought it and the reservoir fluid is dark its most likely just dirty and needing a flush. If your radiator fluid was dark black with oil in it your oil would be low and it would smell pretty bad. I think you probably just need a good radiator flush, if you do it yourself make sure you put in the right fluid your vehicle to keep that waterpump safe. Hope this helps.
Certified Mechanic
9 years experience
Auto Business Owner
Tuffdrvr88 is offline   Reply With Quote
