Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 05-17-2006, 02:23 PM
graygoose graygoose is offline
possible to delete a cat converter on my buick riv?
Its it possible to do a mod with my cat so I can get more hp?
1996 buick riv s/c
Old 05-17-2006, 04:46 PM
96riviera18 96riviera18 is offline
Re: possible to delete a cat converter on my buick riv?
like install a high-flo cat? it wont help that much(you may not feel a difference in driving) but every little bit helps. you would be better off investing in a larger downpipe with the high flo cat and making the T split into a Y.(making all the pipes .5" or .75" larger all the way is a good idea too.) dont forget if you do a lot of exhaust mods you will lose low end torque at the expense of upper end hp.
Old 05-17-2006, 05:40 PM
Oh really? well I heard people who just do a cat delete...I know its illegal but id do it if I knew how
Old 05-17-2006, 06:09 PM
its just as it sounds, cat delete. completely removing the cat from the car and replacing it with a pipe. you could try to cut it out and MIG weld a pipe in yourself but if your not a good welder then you could have leaks and thats not a good thing for a daily driver (you might not wake up at a long stop light). as long as your state doent have inspections then your fine.
Old 05-18-2006, 01:20 AM
plathegame plathegame is offline
if you have an ob2 car you may set a catylist code if you take off the converter.. you may also screw up the back pressure
06 sierra denali 6.0 max
66 grand prix 389
00 caddy escalade 5.7
95 riviera supercharged 3800
85 park avenue 3.8
86 trans am 5.0 tpi
Old 05-18-2006, 09:43 AM
you'll need to get an 02 emulator to stop the code from setting and with the 3.4" pulley you will have plenty of back pressure to spare.
Old 05-18-2006, 12:17 PM
what is back pressure exactly is that like torque?
