Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-28-2005, 12:03 AM   #1
95oldscutlass
'95 3.1L-removing rear exh. manifold...lowering drivetrain/front frame assembly?
I am getting ready to start a head gasket job on my friends 3.1L V6. I have been going through the Chilton manual I have and getting prepared...
I think this job will go pretty smooth (as long as the heads check out okay), since the 3.1L isn't a DOHC engine....if it was I probably wouldn't even attempt changing the head gaskets....
Anyways, I have a question regarding the removal of the rear exhaust manifold. From what it seems, doing this will be one of the biggest challenges.
In the steps provided, I come across "Unfasten the rear drivetrain the front suspension frame bolts/screws. Carefully lower the drivetrain and front suspension frame assembly." This is exactly how it is in the manual...there seems to be a typo..
Well, I looked through the manual on doing this and it is kind of hard to picture what is going on here. Does this completely lower the engine/transaxle out from under? Is this difficult to do? Is it necessary?
Any info on removing the rear exhaust manifold would be very helful. I could probably figure it out when I get to it, but it would be nice with a little heads up before I start...
I am confident in doing everything else that is envolved....just removing that exhaust manifold is the only thing I am unsure about.
I would appreciate any help...
Thanks
95oldscutlass is offline   Reply With Quote
Old 08-28-2005, 08:24 AM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
Re: '95 3.1L-removing rear exh. manifold...lowering drivetrain/front frame assembly?
Disconnect the exhaust down pipe and the cross over pipe from the manifold and pull the manifold and head off as an assembly
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 08-28-2005, 01:40 PM   #3
95oldscutlass
Re: Re: '95 3.1L-removing rear exh. manifold...lowering drivetrain/front frame assembly?
Thanks for the response...I was thinking of this, but wasn't sure if there was enough room to do it. Apparently it is possible. Thanks for saving me some time and some headaches
Old 08-28-2005, 01:44 PM   #4
timguyli
ok whats up with the pass side front motor mount? The piece the dogbone ia attached to wont budge!
timguyli is offline   Reply With Quote
Old 05-03-2006, 09:17 PM   #5
fusion27
can i get some info on removing the head on my 96 ceira, do id have to remove the hold intake system to get the head off?
fusion27 is offline   Reply With Quote
