Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Register FAQ Social Groups
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 12-31-2005, 12:17 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
CO2 injection
instead of water or alcohol injection, could someone inject co2 into the intake to cool it down? you wouldn't lose performance because you'd get denser air so there would be the same ammount, if not more, of air. you could use it as an emergency system if your engine started knocking. also it would be cheaper than a water injection system because you could use a nitrous nozzle and a small co2 canester (like 10lbs or something) to last until you found the problem or until you adjusted your boost settings. it wouldn't be used like water where it's a frequently used thing.
Old 12-31-2005, 11:43 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: CO2 injection
ya know C02 is used to extinguish fires right?
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-31-2005, 12:37 PM
Re: CO2 injection
it extinguishes fires because it surrounds it and doesn't let oxygen get to whatever's burning. if you use it in the intake in small quantities, you should be able to cool it down a bit, enough so that you don't bust an engine.
Old 12-31-2005, 01:29 PM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: CO2 injection
doesnt work that way, you will just kill performance. Sure it will prevent knocking, because its killing performance.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 12-31-2005, 04:15 PM
Reed Reed is offline
Send a message via AIM to Reed
Re: CO2 injection
it robs the engine of oxygen. it is bad to get in your intake.
Cars are like music.
If it ain't fast it ain't shit.
Old 01-01-2006, 11:51 AM
-Jayson-'s Avatar
Re: CO2 injection
now if you wanted to be brave you could try O2 injection
2009 Ninja 650 R
stock for now...
Old 01-01-2006, 01:30 PM
Re: CO2 injection
i don't particularily like the thought of my intake catching fire when i inject it, or my heads, valves, pistons, cylenders, etc. plus there would be massive detonation.
Old 01-01-2006, 01:31 PM
Re: CO2 injection
actually, you might be able to run an engine on just oxygen and say kerosene or diesel. make it a 2 stroke and it injects oxygen and fuel which burn as they're injected and then when the piston reaches the bottom a valve opens for the exhaust. ill have to try it one day.
Old 01-01-2006, 11:32 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: CO2 injection
it doesn't have enough mass to dissipate heat anyways...
Water does. And water turns into steam when its heated. What does the same mass of CO2 turn into when its heated?
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 01-02-2006, 12:24 AM
Re: CO2 injection
true true, i was just trying to think of an inexpensive way to decrease intake temps in the case of bad knocking w/o knock sensor that was easy to set up. all you would need is a small tank of CO2(cheap) some lines and nozzle from a nitrouse kit(cheap) a solenoid from a nitrous kit and a switch(cheap).
Old 01-04-2006, 11:36 AM
-Jayson-'s Avatar
Re: CO2 injection
there are companys that make something similar. They put a bulb inside your intake, and when its activated the bulb/radiator, whatever it is, fills with C02 and cools the air that passes over it.
2009 Ninja 650 R
stock for now...
Old 01-04-2006, 12:09 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: CO2 injection
CO2 is used in a coil around the intake as well to cool the intake down, however its perfomrance gains arent all the great. on intercoolers, however, it works wonders
Old 04-04-2006, 06:33 PM
hardparts hardparts is offline
Re: CO2 injection
They already sell co2 kits to install in your car. I've been selling them for 2 years and it works
design engineering
Cry02 Systems
The CryO² is a revolutionary new, award wining product designed to reduce the temperature of the air/fuel intake charge thus creating power. Through the science of aerodynamics and cryogenics, Design Engineering has developed a system to harness the cryogenic properties of liquid Co² to lower the air/fuel intake charge by up to 60%. The system is modular and can be easily expanded. The CryO² system provides two methods of cooling the air charge and one method of cooling the fuel charge, all utilizing the same burst of liquid Co². Co² is readily available at any welding supply shop or where paintball guns are charged. Welcome to the future of power.
http://www.hard-parts.org/forum
New automotive tech site.
Just opened, come join us.
Old 04-05-2006, 11:21 AM
Re: CO2 injection
design engineering
Cry02 Systems
The CryOČ is a revolutionary new, award wining product designed to reduce the temperature of the air/fuel intake charge thus creating power. Through the science of aerodynamics and cryogenics, Design Engineering has developed a system to harness the cryogenic properties of liquid CoČ to lower the air/fuel intake charge by up to 60%. The system is modular and can be easily expanded. The CryOČ system provides two methods of cooling the air charge and one method of cooling the fuel charge, all utilizing the same burst of liquid CoČ. CoČ is readily available at any welding supply shop or where paintball guns are charged. Welcome to the future of power.
Were talking about spraying CO2 into the combustion chamber. With the CryO2 system, CO2 is passed into a bulb into the intake where it cools the oncoming air by convection as the air passes by the bulb. As for the fuel charge, you place an extension on the fuel rail thats cooled. Again, CO2 is not sprayed directly into the fuel or the intake for combustion.
"The CEG Nazi"
www.contour.org
Old 04-05-2006, 01:16 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: CO2 injection
CO2 could be used in place of N20, but here's why you don't.
CO2 - 1 Carbon atom and 2 Oxygen atoms
What do you NOT want to build up in your engine? Carbon.
N20 Is used because the Nitrogen molecule is burned as well, and burns clean leaving no residue behind.
Simple explanation for a simple question.
