| Engine intakes, exhaust, turbos, nitrous. |
JWT POP vs. STILLEN POP
I have a 1994 G20t. There is some sort of air sensor imbedded in the side of the stock air box. I want to get a JWT POP charger but I have heard that it has no spot to put the sensor. STILLEN on the other hand, lets you choose between 2 (w/sensor or without sensor).
STILLEN INTAKE +HI FLOW INTAKE, 94-6, G-20 W/SENSOR 94-96 STILLEN INTAKE +HI FLOW INTAKE, 91-4 SER/NX/G-20 91-94 Even though the JWT is a much better price, I don't want to get it and have no place to put the air sensor. Can anyone help?? |
Re: JWT POP vs. STILLEN POP
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
My $tillen intake was originally purchased in '94 for my '91 NX2000 w/o sensor. I sold the NX and put the intake on my '96 G20 w/sensor. I purchased a new K&N filter and wanted to attach the sensor to it. Here is what I did:
1. I used the brass plate from the sensor for a template to drill the holes on the chrome end cap of the K&N filter. For aesthetic purposes I mounted the sensor below the K&N logo (see pics) 2. I used a small knife and needle nose pliers and pulled off the rubber from inside the filter so that I could use the original sensor bracket and screws. This makes for a flush fit. 3. Installed the K&N on the $tillen intake and Voila'
Brandon '96 G20 - modified |
My filter has more filter surface at the end and no metal endcap. Regarding tie-wrapping the sensor to the filter surface, aren't you going to get filter oil on the sensor and get false readings as a result?
George, what happens if you over oil the filter? Do the engine suck that oil? Does it cause any damage?
================== Americo 2000 Primera.
Since I couldn't mount the sensor in the end (due to not having a solid endcap to mount it to), I ended up mounting it on the opposite surface on the flat base next to the clamp. It had to remove a couple of layers of gasket off of the sensor but it fit nicely. This is actually very close to the factory mounting loaction so I was able to use the original bracket too for a more finished look.
I couldn't see myself paying all that money for a pop charger so my friends was nice enough to custom make one for me. He drilled a hole for the sensor behind the filter and it works great.
