Old 07-14-2002, 07:13 AM   #1
gustavo
Question High pitched whine
When I set the keys of my car to the position previous to Start, the injection light appears on the panel for a few seconds, as I was told by the representative it indicates the injection computer is doing auto checking. Along the light you can hear a high pitched whine that goes off when the light goes off.
Yesterday I noticed that this high pitched whine continued as I start the engine, the noise of the engine hides it but paying due attention you can hear it there.
Now, I don’t have any idea what this noise is and if it should persist after the engine starts, could you help me understanding what is it all about?
Thanks Gustavo.-
gustavo is offline   Reply With Quote
Old 07-14-2002, 07:21 AM   #2
Moppie
Master Connector
Moppie's Avatar
Knowing what sort of car it is always helps.
But my first guess would be its the fuel pump.
This runs as soon as you turn the ignition on and pressurises the fuel system.
Moppie is offline   Reply With Quote
Old 07-14-2002, 08:35 AM   #3
gustavo
Moppie:
Is a Fiat Palio 1300 cc multi point injection 8 valves gasoline feeded.
My question is if it could be sign of any problem or if is normal.
Thanks Gustavo.-
Old 07-14-2002, 09:00 AM   #4
Moppie
Master Connector
Moppie's Avatar
What year is it?
I doubt it's anything abnormal.
All electric pumps are quite noisy, and on most cars they are actualy in the fuel tank, which dampens the noise.
However some cars, especialy older injected ones will have the pump in the boot, under the car, or in the engine bay.
In these cars it's quite common to be able to hear it.
The other option is its some like and engine fan running constantly, or interferance from the ignition system effecting the radio.
But thier both easy to spot, if you open the bonnet you'll soon know if the fan is running. And you will be able to hear any interferance coming from the speakers.
Old 07-14-2002, 01:28 PM   #5
gustavo
It is a 1997 model, bought december 30 1997.
It has run just 33,335 kilometres.
Thanks Gustavo.-
intermittent high pitched whine from heater rbnbird E-Class 1 11-10-2005 07:33 PM
95 civic 5spd high pitch whine from trans dunno77 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 06-05-2005 12:29 AM
High pitched whine from engine area heylownine Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 4 03-22-2005 06:40 PM
2000 Bravada - High pitched whine chadshu Bravada 3 01-26-2005 11:57 PM
High Pitched Whine fester_wi Neon | Plymouth Neon 4 12-25-2003 09:05 PM
