Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-21-2006, 07:08 PM   #1
swp5767
swp5767's Avatar
My clock resets on the factory radio
As least every other day, I notice my clock has started at 1:00 again. It does not loose the station programming, but the clock resets. As far as I know, the truck is not loosing power of any kind.
Any ideas?
Thanks
swp5767 is offline   Reply With Quote
Old 02-21-2006, 07:15 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: My clock resets on the factory radio
Check all power and ground feeds to it.
May be telling you it is time for one of the new radios
MT
MT
Old 02-21-2006, 07:29 PM   #3
swp5767
swp5767's Avatar
Hey pal, dont be hating on the factory radio.
An upgrade is on the horizon.
Old 02-21-2006, 07:43 PM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Smile Re: My clock resets on the factory radio
No problem I hate radios in a car anyway. I would rather listen to my engine run.
But some people can not drive without them. Including my wife.
MT
MT
Old 02-21-2006, 07:49 PM   #5
2000CAYukon
What year is your Yukon? My 3 year old son like to play with the reading lights. Sometimes, if the light is on long enough, the clock will reset. Not sure what year it started but my 2000 has battery run down protection and power to the radio is one of things that is cut if the battery gets low enough.
You could have a bad battery or something is drawing power causing the run down protection to kick in.
//2000CAYukon
2000CAYukon is offline   Reply With Quote
Old 02-21-2006, 08:16 PM   #6
swp5767
swp5767's Avatar
I have a 97 Tahoe. I guess I didnt mention that earlier.
Old 02-26-2006, 12:04 AM   #7
aznjeep
aznjeep's Avatar
My 2003 Tahoe was doing the exact same thing last October ('05). It turned out that the battery terminals were badly corroded. The draw from the starter basically was causing a mild short in the system, which actually damaged the battery. I cleaned the terminals (replaced the bolts for the side post), dropped in a new battery, and problem solved.
aznjeep is offline   Reply With Quote
Old 03-18-2006, 10:42 PM   #8
teknology
Send a message via AIM to teknology Send a message via MSN to teknology Send a message via Yahoo to teknology
all radios come with a memory wire,(+12 volts), das a memory wire problem. sounds like it's disconnected or cut. what the wire does, is hold settings and time of you radio while the ignition is off.
teknology is offline   Reply With Quote
