Old 02-21-2006, 02:36 PM
nyoi4fib nyoi4fib is offline
Fuel Pump help
Hi guys!. I have a question about a '92 Camaro Rs V8.
When I turn the key off I hear a humming/buzzing from the fuel tank. I disconnect the bat. and it stops. I connected the bat. back up and it still drains the bat. dead. I have tried pulling fuses to make it stop, but no luck there. It just started a couple of weeks ago. I replaced the fuel pump about 3 years ago. Could it be bad already? I have heard everything from the relay to the pump itself being bad. When I jump the car off, it starts up fine. It runs fine, no sputtering, rough idling or anything. Any opinions or suggestions would be very appreciative right now as I am at a dead end. I am not ready to spend another $500 putting another pump on.
Old 02-21-2006, 03:46 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: Fuel Pump help
That sound you're hearing is the pump priming, it's normal(and aftermarket pumps are considerably louder than stock) I doubt it's the fuel pump if it starts...I would take a closer look at your battery. Test the battery when you jump it, if it starts to lose volts then it could be your alternator.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 02-21-2006, 04:00 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Fuel Pump help
the pump won't be priming when you "turn the key off"
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 02-21-2006, 04:11 PM
SG007's Avatar
Re: Fuel Pump help
It still primes if it's turned in the ignition.
Old 02-21-2006, 05:13 PM
Re: Fuel Pump help
It only primes when the key is turned ahead, prior to starting the car, not when turning the car off. It sounds like his problem is that the pump will not turn off?
Old 02-21-2006, 05:17 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Fuel Pump help
the pump don't keep on priming till the batter is dead, it might run for about no more than 30sec after the car is shut off but that is it. Like cuda said, you have a problem with your pump not shuting off. So did you try to pull the fuel pump fuse and then check to see if you still here it.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-21-2006, 07:43 PM
SG007's Avatar
Re: Fuel Pump help
He said he tried pulling fuses though...
Old 02-21-2006, 08:14 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Fuel Pump help
fuel pump fuse is under the hood on the right side fender wall behind the battery.
Old 02-21-2006, 10:38 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Re: Fuel Pump help
does your hatch function properly, in my last camaro the hatch motor got messed up and it would always try to pull thye hatch down and when the car shuts off you could hear it and it could be mistaken for a fuel pump.
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 02-21-2006, 10:40 PM
97cavalier's Avatar
Re: Fuel Pump help
wow, never thought of that, that is a good idea!!
Old 02-22-2006, 02:17 AM
Morley Morley is offline
Re: Fuel Pump help
Yes, the fuel pump is supposed to run after the car is shut off, for about 2 seconds, just like when the key is switched on.
Turn the key on and listen for the pump, it should run for 2 seconds and stop. If it keeps going, the relay is stuck and that is why it keeps running after you shut the car off.
Old 02-22-2006, 09:59 AM
SG007's Avatar
Re: Fuel Pump help
gotta love in-tanks. lol
Old 02-23-2006, 01:02 AM
Re: Fuel Pump help
Thanks for all the info. sorry i havent responded sooner. I have not tried the fuse under the hood. will try. and the motor for the hatch works fine, just the hydraulics dont work. I listened for it to prime when i turn the key on. thats fine, it does that and shuts off. i can take the key outta the switch and still hear the humming. and btw, please bear with me, i am a woman, so if i sound like i dont know what i am talking about, i probably dont. LOL. But thank again.
Old 02-23-2006, 02:32 AM
Re: Fuel Pump help
If the struts are not holding the hatch up and you have the pull down motor hatch, get new struts on the hatch ASAP. Bad struts will kill the pull down motor & housing.
Is the humming sound the same as when you turn the key on and the pump primes?
Old 02-23-2006, 04:38 AM
Re: Fuel Pump help
No its a different sound. when the car is off, it just a low hum. another question though, if it is the relay is that also located in the tank?
