Old 07-22-2007, 06:15 PM   #1
sgtstew
Crank Position Sensor - '93 3.1 Euro
Is the CPS a screw-in device? In some posts, I have read about loosening the rubber o-ring with brake cleaner. OR... is this just to be able to unplug the electrical connector.
Also, there are words that relate to being able to take off the oil pan and push the CPS out from within. I'm a bit confused....
Thanks
sgtstew is offline   Reply With Quote
Old 07-22-2007, 08:15 PM   #2
john51md
Re: Crank Position Sensor - '93 3.1 Euro
Thanks
It has a small flat base that sits against the engine block, sorta egg shaped, the sensor sits on the right side of the egg, and the attaching bolt sits on the left side of the egg, sorta a oval flat base, once you remove the nut holding it in, it has a O ring seal on its shadt portion that protrudes into the block, O ring is to prevent oil loss, how ever the O ring gets hard and gunked up with burnt oil film and doesnt want to come out, so soaking it in anything that will disolve oil/grease/etc will help loosen it up, then gently twist and pull, if you break it off, oil pan removal is only way to get at the lower end and push it out. Take you time, lube over and over, twist easy..
john51md is offline   Reply With Quote
