Old 01-30-2006, 05:04 AM   #1
nickledimed
nickledimed's Avatar
Send a message via Yahoo to nickledimed
anouther tire question
I have a 98 chevy blazer LT, 4x4, 4.3, towing package, trany cooler....stock
My question is will a 235\70\15 on my stock rims fit?...I know 235\75\15 will fit, but I like the wider tire. I wouldnt go any taller than the 235.
I had a toy pu with something similar and the stance looked pretty mean...thats what im looking for....
nickledimed is offline   Reply With Quote
Old 01-30-2006, 07:30 AM   #2
mike2004tct
mike2004tct's Avatar
Re: anouther tire question
235 is the width. 70 or 75 is the aspect ratio for the height, as in 70% of 235 is the height, so with a 235/70 tire, the height is 164.5mm. On a 235/75 tire, the height is 176.25mm.
On stock rims, 235 is the recommended max width. For 245 and up wider tires, you'll need to go with wider rims. The stock rims are 7" wide (I think), and you'd need 8 to 9" wide rims for wider tires.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
mike2004tct is offline   Reply With Quote
Old 01-30-2006, 09:33 PM   #3
nickledimed
how about 31x12.5x15? or would 12.5 be too wide? maybe 10.5?
Im going to go with an AT tire.
Old 01-30-2006, 09:45 PM   #4
blazee
Problem?
blazee's Avatar
I run 265/70/15 BF Goodrich Long Trail T/A on stock rims. They take up most of the fenderwells, with zero rubbing.
blazee is offline   Reply With Quote
Old 01-30-2006, 10:59 PM   #5
nickledimed
Blazee, you wouldnt happen to have some side view and front veiw pics of that s10 would you?....sounds like just what Im looking for.
Old 01-31-2006, 07:45 AM   #6
mike2004tct
265s on stock rims??? Do they bulge at the sidewalls at all?
Here's a front pic of what 255/50/16s look like.
These are on Corvette rims. I only had them on for a cruise around the block.
They didn't rub either, but the profile was too low, so I took them off.
Old 01-31-2006, 09:26 AM   #7
nickledimed
I realy like that Mike...that looks about like what Im looking for...maybe a little taller though...got a side veiw of that beast?...also I would realy like to keep the stock 15s.
08 Equinox LT
Old 01-31-2006, 12:22 PM   #8
mike2004tct
Remember, this was done just as a joke by me.
These wheels and tires are off of my Corvette. As someone said in my original post, they look like HotWheels tires.
I would guess that Blazee's tires are close to the same width (mine are 255s, his are 265s - about 4/10 of an inch wider for the 265s)
My point is, even with the wider tires and the correct wheel offset, they still don't stick out of the wheel wells. Personally, I think tires and wheels protruding outside the wells are dumb (unless you have the bolt-on fender flares)
Back view
Side view
Old 01-31-2006, 12:38 PM   #9
blazee
Problem?
blazee's Avatar
Mine are about the same width as the ones in Mike's pictures. They are a lot taller though and take up most of the fenderwells. They don't stick out past the fenders, and look normal on the rims (no large or abnormal bulges). If I get time later I'll post some pics.
Old 01-31-2006, 05:24 PM   #10
laxman21
laxman21's Avatar
I run 30x9.50s.
31x10.50 will rub with stock rims.
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
laxman21 is offline   Reply With Quote
