Old 01-15-2006, 12:46 PM   #1
johnnyh
whats evap line???
i was told that my EVAP line might be loose and to check that but i have no clue what the hell that iscould someone tell me what it is and looks like and where it's located so i can fix the damn thing already!! thanks
johnnyh is offline   Reply With Quote
Old 01-15-2006, 02:57 PM   #2
unbe
Re: whats evap line???
It's hard to go into specifics with no year or engine size but I can tell you it has to do with the line that connects you purge canister to your fuel tank and other components.What makes you think their is a problem did you get an engine code? If that is the case a bad\loose fuel cap can set the same code I think.
unbe is offline   Reply With Quote
Old 01-15-2006, 10:16 PM   #3
johnnyh
well the original problem is that my running temp has all of a sudden shot up about 15 - 20 degrees so instead of 195 it's like 210 or somethin and someone said i need to purge my system and it might be the EVAP line .....so i was wondering what a EVAP line is ..........i have a 2000 2dr 2.2 liter
Old 01-15-2006, 10:23 PM   #4
johnnyh
Old 01-16-2006, 08:49 AM   #5
jakegday
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
if you give me your email address ill scan and email you the entire page in my haynes manual regarding the EVAP on your engine
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
jakegday is offline   Reply With Quote
Old 01-16-2006, 06:50 PM   #6
unbe
Johnnyh
Sounds like they were referring to the line that goes from your radiator to your overflow tank.(coolant recovery).The EVAP I was referring to is different and I don't see how it would be related to your problem.
Unbe
