Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Register FAQ Social Groups
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-16-2006, 06:05 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
Gas Cap????
Everytime I go to fill up my car I hear a HISS as if pressure built up. I only hear it when I open the gas cap. Im assuming that some kind of ventilation is clogged. I dont know if the cap has a built in vent. or if there is some kind of tube by the filler neck. any ideas?
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
Old 01-16-2006, 06:40 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Gas Cap????
Are you hearing a vacuum hiss or a pressure hiss? Vacuum in the tank is normal. Next time you hear the hiss, look for a lot of fumes coming around the cap WHILE it's hissing. If you see a lot of fumes, your EVAP system isn't functioning properly. I suspect everything is normal, however. Do you have a check engine light on?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-16-2006, 06:43 PM
XGamesJ6's Avatar
Re: Gas Cap????
no check engine light is on. ever. it sounds like it could be a vaccum hiss. considering i never smelt or saw anything. but it could be that i was just too fast on it. heard the hiss and removed the cap without a second thought.
Old 01-16-2006, 06:49 PM
Re: Gas Cap????
The EVAP system pulls a vacuum on the tank for a few reasons. Mostly to keep an eye on holes in the tank and to evacuate fuel vapors. I'd say there's nothing wrong..
Old 01-16-2006, 06:52 PM
XGamesJ6's Avatar
Re: Gas Cap????
ok i just wanted to check. i thought maybe something was up because it happened like the last 3 times. but its alright i guess...next time i fill up i'll check for fumes or anything. see if its pressure or a vaccume. thnx for the help
