i recently installed an overhead console in my 1998 blazer. I have tryed calibrating the compass many times, but nothing works. The screen shows 0 C cal NE. I have set the variance correctly. And i tryed holding in ON/OFF and US/MET buttons for 10 seconds. It continues to show 0 C cal NE. I drive in 3- 360 circles around 5 mph. Nothing happens after that.
any help would be great Thanks |
#2 | ||
Re: compass
If yours still refuses to do that, I would suspect you're not tied into the VSS properly.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
i thought i had properly tapped into the VSS wire, but i checked today and the connector wasn't properly installed. i installed it correctly and calibrated it. now the compass works great.
thanks rlith |
Re: compass
OC means open circuit, your temp sensor isn't connected correctly, or the temp sensor has a bad ground.
Your vss connection may not be good as well. |
#5 | ||
Re: Re: compass
#6 | ||
Re: Re: Re: compass
#7 | |
when i said, "0 C" i meant zero degrees celcius.
sorry |
#8 | |
when i said, "0 C" i actually meant zero degrees celcius.
sorry |
#9 | |
Re: compass
Are you sure? Does it show a farhenheit temperature?
#10 | |
yep it works with celcius and farenheit. i have checked several times to see if it is accurate.
