Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-12-2006, 06:58 AM   #1
realalam1
Angry 96 neon problem list
Here is the problems.
Gas gauge does not always work.
Speedometer does not always work.
Battery charge light is on.
Error code 12. Problem with battery connection.
Error code 44. Battery temp in PCM.
I think all my problems are from a bad PCM, has anyone seen this before? Its the PCM or the wire harness.
realalam1 is offline   Reply With Quote
Old 01-12-2006, 08:39 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 96 neon problem list
Read this post to fix these problems...
http://www.automotiveforums.com/vbul...=gauge+cluster
Code 12 - battery has been disconnected within the last 50 key-on cycles (Nothing to worry about)
Code 44 - Battery temp sensor volts out of range (your battery sensor may be bad, it's in the battery tray on the right hand side if you are standing in front of the vehicle)
das2123 is offline   Reply With Quote
Old 01-12-2006, 07:16 PM   #3
realalam1
Re: Re: 96 neon problem list
A COLD SOLDER JOINT? Will this because of a cold solder joint. I'll try the fix.
Now for the battery temp sensor, where can find one? Parts America doesn't show them as an item they carry. Is it a dealer only item?
Old 01-12-2006, 10:09 PM   #4
das2123
Fix the cluster first, that may be whats setting off the battery sensor. You never know. The gauge cluster needs to be reflowed.
Old 01-18-2006, 10:35 PM   #5
ryandotcom
ryandotcom's Avatar
Send a message via Yahoo to ryandotcom
I just bought a 96 and i noticed after i use about 4 gallons the gas gauge goes to empty then dances up and down. The other problems havent showed up yet.
ryandotcom is offline   Reply With Quote
Old 01-19-2006, 09:03 AM   #6
das2123
Sounds like your fuel gauge sending unit(sensor) is going out on you. It's attached to the side of the fuel pump module.
