Go Back   Automotive Forums .com Car Chat > Mercury > Villager
Old 01-23-2006, 10:06 PM   #1
chubbygoatboy
2000 villager front end sqwauk noise
I know this has been addressed before, but I don't know if there was ever a good answer. Our 2000 Estate has this noise that when you are going around a turn, or going in or out of a sloped drive from the street, has a sqwauk noise in the front end. It happened shortly after warranty ran out, now has 106k on it. I have replaced lower ball joints, struts and upper strut mounting plates. Even the CV joints have been replaced. It still does it. ANY IDEAS?????
chubbygoatboy is offline   Reply With Quote
Old 01-24-2006, 09:01 AM   #2
Eddie45
Re: 2000 villager front end sqwauk noise
I had the exact same symptoms as you described. I replaced both front driveaxles with rebuilt ones, and that took care of the problem.
Good luck
Eddie45 is offline   Reply With Quote
Old 01-24-2006, 09:32 AM   #3
chubbygoatboy
Thanks for the response, but I have done the axles as well, with no change in the goose sqwauk noise. Any other ideas????
Old 01-24-2006, 10:21 AM   #4
Eddie45
Did you replace the CV joints youself? If not, are you sure that it wasn't only the boots that were replaced? When I replaced the driveaxles 3 weeks ago, I did the job myself because long time ago I had bad experience (on another vehicle) where the autoshop was supposed to replace the CV joint and the boot, but I soon found out they only replaced the busted boot.
Old 01-24-2006, 11:33 AM   #5
Hollowcreek
My noise went away after the drive axles were replaced, but I cannot be sure if it was the axles or due to the disassembly/ assembly process.
Hollowcreek is offline   Reply With Quote
Old 01-24-2006, 11:44 AM   #6
carlos80
sounds like it might be your stabilizer bar bushings and links
carlos80 is offline   Reply With Quote
Old 01-24-2006, 12:33 PM   #7
chubbygoatboy
I appreciate the responses!! I did the axles myself. I also had replaced the lower control arm on the left, because I was sure those bushings was were the noise was coming from, and you have to replace the entire arm. So I did, along with lower balljoint, still had no effect. If it is in the stabilzer/sway bushings, is there a fix? Or do I need to replace all of the bushing? THANKS!!
