Go Back   Automotive Forums .com Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 04-22-2005, 04:20 PM   #1
dzbuster
Send a message via Yahoo to dzbuster
88 n/a overheats
i replaced the radiator water pump and thermostat. car runs hot then quickly cools down to normal. loses fluid through overflow tank. no fluid in oil or oil in fluid. seems like thermo sticks. replaced thermostat again same thing. flushed system still same. know not good for mileage but going to run w/o thermostat see how it goes. any suggestions would be appreciated. thank you
dzbuster is offline   Reply With Quote
Old 04-22-2005, 06:18 PM   #2
dzbuster
still overheats i'm stumped
Old 05-01-2005, 04:35 PM   #3
november-ice
Re: 88 n/a overheats
mines doing the same thing machanic says blown headgasket
november-ice is offline   Reply With Quote
Old 05-01-2005, 05:02 PM   #4
dzbuster
heard that from friends although was told gasket is good. thank you for the bad news.
Old 05-01-2005, 10:08 PM   #5
hartdlh
I would bet money that its your hg, i had the same problem it turned out to be a bhg. i replaced my water pump, thermo, and fan clutch hoping that it would be one of those.
hartdlh is offline   Reply With Quote
Old 01-05-2006, 09:09 PM   #6
mike7339
its the head gasket i had the same problem on my 86.5 supra na it was the head gasket
mike7339 is offline   Reply With Quote
Old 01-05-2006, 10:01 PM   #7
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
Have you run any cleaner through the system. You may have a clog in the water jacket. Have you done a compression test to make sure the HG is good?
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
TcmaBoy is offline   Reply With Quote
Old 01-05-2006, 10:02 PM   #8
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
Have you run any cleaner through the system? You may have a clog in the water jacket. There also may be a problem with the heater core. Bypass it and see if the car still overheats. Have you done a compression test to make sure the HG is good?
Old 01-09-2006, 09:25 PM   #9
sb5551
I had the same problem with my car, although it might be the head gasket i had a small coolant leak in the very back of the engine that would only leak a little and cause it to over heat but the temp gauge would jump around depending on the engine load. However the engie would never completly drain an air bubble would always form feel the top radiator hose when its hot and see if you squeeze it if you cant it has an air bubble
sb5551 is offline   Reply With Quote
Old 01-10-2006, 01:08 AM   #10
Yellow 13
Yellow 13's Avatar
Send a message via AIM to Yellow 13
Its the HG, I had the same problem with one of my supras.
Yellow 13 is offline   Reply With Quote
