Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Register FAQ Social Groups
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-06-2005, 04:29 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
Tail Lights Dont Work
Ok, so recently my left blinker/break light go out, so I replace the bulbs and they work fine!
Then I notice that my actaul tail lights are out at night... I replace the bulbs and check the interior fuse that says tail lamps, and the exterior square fuse that says tail lamps but the exterior one is more of a cube thing and doesnt seem like a standard fuse for a car...
I dont see any rips in any of the wires in the trunk or the wiring harness under the car...
How do I go about fixing this anyone?
I have a 96 spyder GS eclipse.
Old 12-06-2005, 06:10 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
im not sure if it is the same as your case, but my friends 95 gs has got a right side tail light/turn signal problem. sometimes it just quits. the problem seems to be the sockets. if i sit back there and wiggle the socket i can get it to work. i dont know if you have tried messing with the sockets or not but you should.
Old 12-06-2005, 11:28 PM
inatalonIXLR8 inatalonIXLR8 is offline
Re: Tail Lights Dont Work
Maybe the bulb sockets have corroded. Also double check at a couple parts stores to make sure you have the right bubs in there.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
